time-nuts@lists.febo.com
Re: [time-nuts] time-nuts Digest, Vol 66, Issue 55
DM
Dick Moore
Tue, Jan 12, 2010 6:04 AM
Nic, many times volt-nut questions are posted here, including by me, and no one has ever said "get outta here, we're TIME-NUTS."
I currently have two 732As, a Fluke 5440B, a couple of Datron 1082s, and not too long ago got an HP3458A and had it cal'd by HP in Loveland. One thing I've discovered so far about the 732As is that you really only need one unless you're a belt-and-suspender kind of guy. Either of mine reliably return to better than 0.1ppm of base from several cold starts, given a warm-up of a day or so, so I've dispensed with the batteries completely. Over the last few months, the two 732s track within 0.05ppm as measured by the 3458, which also tells me that the 3458 is pretty good too.
I know of no other "volt-nut" sites, but others here may know of some -- I hope they do. I do have a web site of my own, but I haven't yet set up a volt-nut blog -- I'm looking at the Phorum open-source software for another project, and if I think the traffic won't be real high (how could it?) then I'll look into the possibility of hosting such a thing. In the mean time, Volt On!!
Dic k Moore
Message: 6
Date: Tue, 12 Jan 2010 14:12:14 +1100
Subject: [time-nuts] I think I've become a Volt nut too.
To: "'Discussion of precise time and frequency measurement'"
time-nuts@febo.com
Message-ID: CFE28E8002D6404D8D4ED951037C1946@PC755913417801
Content-Type: text/plain; charset="us-ascii"
Hi All,
I have been a time nut for some time now. I think I've become a Volt nut
too! I build the Silicon Chip magazine Voltage reference late last year but
didn't have anything to compare it against so I bought a Fluke 732A DC
reference standard.
I there a group I can subscribe to that can help me with this?
Can I coin the phrase; A man that has one DC Voltage standard knows how
accurate his meter is, whereas a man with two standards is not quite sure!
Regards,
Nic
VK2KXN VK5ZAT
Nic, many times volt-nut questions are posted here, including by me, and no one has ever said "get outta here, we're TIME-NUTS." I currently have two 732As, a Fluke 5440B, a couple of Datron 1082s, and not too long ago got an HP3458A and had it cal'd by HP in Loveland. One thing I've discovered so far about the 732As is that you really only need one unless you're a belt-and-suspender kind of guy. Either of mine reliably return to better than 0.1ppm of base from several cold starts, given a warm-up of a day or so, so I've dispensed with the batteries completely. Over the last few months, the two 732s track within 0.05ppm as measured by the 3458, which also tells me that the 3458 is pretty good too. I know of no other "volt-nut" sites, but others here may know of some -- I hope they do. I do have a web site of my own, but I haven't yet set up a volt-nut blog -- I'm looking at the Phorum open-source software for another project, and if I think the traffic won't be real high (how could it?) then I'll look into the possibility of hosting such a thing. In the mean time, Volt On!! Dic k Moore > Message: 6 > Date: Tue, 12 Jan 2010 14:12:14 +1100 > From: "Nic McLean" <mcleann@bigpond.com> > Subject: [time-nuts] I think I've become a Volt nut too. > To: "'Discussion of precise time and frequency measurement'" > <time-nuts@febo.com> > Message-ID: <CFE28E8002D6404D8D4ED951037C1946@PC755913417801> > Content-Type: text/plain; charset="us-ascii" > > Hi All, > > I have been a time nut for some time now. I think I've become a Volt nut > too! I build the Silicon Chip magazine Voltage reference late last year but > didn't have anything to compare it against so I bought a Fluke 732A DC > reference standard. > > > > I there a group I can subscribe to that can help me with this? > > > > Can I coin the phrase; A man that has one DC Voltage standard knows how > accurate his meter is, whereas a man with two standards is not quite sure! > > > > Regards, > > Nic > > VK2KXN VK5ZAT >
CH
Chuck Harris
Tue, Jan 12, 2010 3:53 PM
Do a search on volt-nuts.
volt-nuts@febo.com
Volt-nuts is populated by many of the members
of time-nuts.
-Chuck
TIME-NUTS."
too.
Dic k Moore
Do a search on volt-nuts. <volt-nuts@febo.com> Volt-nuts is populated by many of the members of time-nuts. -Chuck Dick Moore wrote: > Nic, many times volt-nut questions are posted here, including by me, and no one has ever said "get outta here, we're > TIME-NUTS." > > I currently have two 732As, a Fluke 5440B, a couple of Datron 1082s, and not too long ago got an HP3458A and had it > cal'd by HP in Loveland. One thing I've discovered so far about the 732As is that you really only need one unless > you're a belt-and-suspender kind of guy. Either of mine reliably return to better than 0.1ppm of base from several > cold starts, given a warm-up of a day or so, so I've dispensed with the batteries completely. Over the last few > months, the two 732s track within 0.05ppm as measured by the 3458, which also tells me that the 3458 is pretty good > too. > > I know of no other "volt-nut" sites, but others here may know of some -- I hope they do. I do have a web site of my > own, but I haven't yet set up a volt-nut blog -- I'm looking at the Phorum open-source software for another project, > and if I think the traffic won't be real high (how could it?) then I'll look into the possibility of hosting such a > thing. In the mean time, Volt On!! > > Dic k Moore
