trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Diesel Fuel system design
MA
Mark Andrew
Wed, Oct 10, 2007 5:48 PM
Greetings.  This has probably already been covered in years past, but
scanning the archives appears to be a chore unless someone would suggest how
to do a global search on the various monthly archive files.
I'm rebuilding an engine room from scratch on a 56' steel trawler (circa
1955).  I've spec'd out Racor filters and the ESI polishing system and will
have several manifolds sending fuel from one of assorted fuel tanks to the
various fuel 'users' (main engine, gen set, furnace), and again with their
'return' lines.
My question:
What would be the ideal fittings and hose types I should use?  Should I hard
pipe the fuel lines, except for the last little length to the engines?  If
so, should this be in copper, stainless?
For fittings, what type do you recommend?  Any 'makes' preferred over
others?  Is 37 SIC preferred over 45 SAE.or something else completely?  Are
these even the preferred terms?
Basically I've got the various items to connect, but need help with what to
connect them with.
Thanks in advance,
Mark
"Black River"
Holland, MI
[demime 1.01d removed an attachment of type image/gif which had a name of image001.gif]
Greetings. This has probably already been covered in years past, but scanning the archives appears to be a chore unless someone would suggest how to do a global search on the various monthly archive files. I'm rebuilding an engine room from scratch on a 56' steel trawler (circa 1955). I've spec'd out Racor filters and the ESI polishing system and will have several manifolds sending fuel from one of assorted fuel tanks to the various fuel 'users' (main engine, gen set, furnace), and again with their 'return' lines. My question: What would be the ideal fittings and hose types I should use? Should I hard pipe the fuel lines, except for the last little length to the engines? If so, should this be in copper, stainless? For fittings, what type do you recommend? Any 'makes' preferred over others? Is 37 SIC preferred over 45 SAE.or something else completely? Are these even the preferred terms? Basically I've got the various items to connect, but need help with what to connect them with. Thanks in advance, Mark "Black River" Holland, MI [demime 1.01d removed an attachment of type image/gif which had a name of image001.gif]
B
Benson,Joe
Wed, Oct 10, 2007 6:03 PM
See the current issue of Passagemaker.  Steve D'Antonio has a good
article on just this topic.
Joe Benson
-----Original Message-----
From: trawlers-and-trawlering-bounces@lists.samurai.com
[mailto:trawlers-and-trawlering-bounces@lists.samurai.com] On Behalf Of
Mark Andrew
Sent: Wednesday, October 10, 2007 12:48 PM
To: trawlers-and-trawlering@lists.samurai.com
Subject: T&T: Diesel Fuel system design
how
will
the
their
'return' lines.
My question:
hard
If
Are
to
connect them with.
Thanks in advance,
Mark
"Black River"
Holland, MI
of image001.gif]
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe or modify your subscription options (get password, change
email address, etc) go to:
http://lists.samurai.com/mailman/options/trawlers-and-trawlering
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
See the current issue of Passagemaker. Steve D'Antonio has a good article on just this topic. Joe Benson -----Original Message----- From: trawlers-and-trawlering-bounces@lists.samurai.com [mailto:trawlers-and-trawlering-bounces@lists.samurai.com] On Behalf Of Mark Andrew Sent: Wednesday, October 10, 2007 12:48 PM To: trawlers-and-trawlering@lists.samurai.com Subject: T&T: Diesel Fuel system design Greetings. This has probably already been covered in years past, but scanning the archives appears to be a chore unless someone would suggest how to do a global search on the various monthly archive files. I'm rebuilding an engine room from scratch on a 56' steel trawler (circa 1955). I've spec'd out Racor filters and the ESI polishing system and will have several manifolds sending fuel from one of assorted fuel tanks to the various fuel 'users' (main engine, gen set, furnace), and again with their 'return' lines. My question: What would be the ideal fittings and hose types I should use? Should I hard pipe the fuel lines, except for the last little length to the engines? If so, should this be in copper, stainless? For fittings, what type do you recommend? Any 'makes' preferred over others? Is 37 SIC preferred over 45 SAE.or something else completely? Are these even the preferred terms? Basically I've got the various items to connect, but need help with what to connect them with. Thanks in advance, Mark "Black River" Holland, MI [demime 1.01d removed an attachment of type image/gif which had a name of image001.gif] _______________________________________________ http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.samurai.com/mailman/options/trawlers-and-trawlering Trawlers & Trawlering and T&T are trademarks of Water World Productions. Unauthorized use is prohibited.
LN
Larry N. Brown
Wed, Oct 10, 2007 6:33 PM
Mark,
If you have high speed, I can send you some pics of the fuel control panel I
designed and had installed. I had the tanks built with separate engine fuel
suction and return lines and fuel polishing/transfer/priming suction and
return lines. It's based on 3/8" SS Aeroquip braided lines-- think of the
gearwell of a jet-- and fittings.
I can feed any engine/genset from any tank and return to any of the 4 tanks.
8 x 5 way valves. Ditto the fuel transfer/polishing/priming system.
Machinery fuel supply intakes are 3/4" above tank bottom;
transfer/polishing/bleeding are 1/4" above bottom. I use a Gulf Coast filter
F-1 for polishing. When I polish-- tank suction and return to same tank-- I
use a simple on/off switch. When I transfer-- tank suction and return to a
different tank-- I use a spring powered 1 hour timer to prevent fuel spills.
The Walbro 6802 transfers 43 GPH so I take a WAG and set the timer
accordingly.
My hydraulic steering, propane and RO watermaker high pressure systems use
45d SAE. Fuel is 37.5d JIC. This gives more surface area for contact.
Never've seen an air bubble or a fuel leak.
Each main engine and the genset have 2 x Racor 500's, plumbed in so I can
switch them out underway if the vacuum gets high and change out the filter
at anchor. I use 30m filters because the Floscan FF transducers require no
smaller to prevent "bounces". The F-1-- also with vac gauge-- strains down
to < 1 micron. Racor bowls always contain cherry cider fuel.
Regards,
Larry and Teri
M/V Cigano, 47' Prairie Sundeck Cruiser
Lying: Covington, LA
N 30 26.7
W 90 07.1
how
will
'return' lines.
My question:
hard
Are
to
connect them with.
Thanks in advance,
Mark
Mark, If you have high speed, I can send you some pics of the fuel control panel I designed and had installed. I had the tanks built with separate engine fuel suction and return lines and fuel polishing/transfer/priming suction and return lines. It's based on 3/8" SS Aeroquip braided lines-- think of the gearwell of a jet-- and fittings. I can feed any engine/genset from any tank and return to any of the 4 tanks. 8 x 5 way valves. Ditto the fuel transfer/polishing/priming system. Machinery fuel supply intakes are 3/4" above tank bottom; transfer/polishing/bleeding are 1/4" above bottom. I use a Gulf Coast filter F-1 for polishing. When I polish-- tank suction and return to same tank-- I use a simple on/off switch. When I transfer-- tank suction and return to a different tank-- I use a spring powered 1 hour timer to prevent fuel spills. The Walbro 6802 transfers 43 GPH so I take a WAG and set the timer accordingly. My hydraulic steering, propane and RO watermaker high pressure systems use 45d SAE. Fuel is 37.5d JIC. This gives more surface area for contact. Never've seen an air bubble or a fuel leak. Each main engine and the genset have 2 x Racor 500's, plumbed in so I can switch them out underway if the vacuum gets high and change out the filter at anchor. I use 30m filters because the Floscan FF transducers require no smaller to prevent "bounces". The F-1-- also with vac gauge-- strains down to < 1 micron. Racor bowls always contain cherry cider fuel. Regards, Larry and Teri M/V Cigano, 47' Prairie Sundeck Cruiser Lying: Covington, LA N 30 26.7 W 90 07.1 > Greetings. This has probably already been covered in years past, but > scanning the archives appears to be a chore unless someone would suggest > how > to do a global search on the various monthly archive files. > > > > I'm rebuilding an engine room from scratch on a 56' steel trawler (circa > 1955). I've spec'd out Racor filters and the ESI polishing system and > will > have several manifolds sending fuel from one of assorted fuel tanks to the > various fuel 'users' (main engine, gen set, furnace), and again with their > 'return' lines. > > > > My question: > > What would be the ideal fittings and hose types I should use? Should I > hard > pipe the fuel lines, except for the last little length to the engines? If > so, should this be in copper, stainless? > > > > For fittings, what type do you recommend? Any 'makes' preferred over > others? Is 37 SIC preferred over 45 SAE.or something else completely? > Are > these even the preferred terms? > > > > Basically I've got the various items to connect, but need help with what > to > connect them with. > > > > Thanks in advance, > > Mark
SH
Scott H.E. Welch
Thu, Oct 11, 2007 3:01 AM
"Mark Andrew" msandrew@chartermi.net writes:
'return' lines.
I've just finished rebuilding a 60 foot trawler, including a complete
rewiring and replumbing of the engine room (you can see some pictures at
www.islandeagle.net, sadly the website is wayyy out of date). She has a
single engine, a single genset, a single heater, and two fuel tanks.
You're going to get a bunch of answers to your query, mine might be a bit
different.
First, I started out with plans much like yours. A supply manifold, a return
manifold, the whole nine yards. I then got some advice from a couple of folks
I trust a lot, including a commercial ship engineer and a Transport Canada
inspector who's also a captain with 35 years of experience. Here are the high
points of my system:
  1. No supply manifold. I have a single two way valve that lets me select
    between port and starboard tanks. All consumers are fed from that selection.
    Dead simple, and it's pretty hard to come up with a real-world example of why
    you need a more complex system.
  2. No return manifold. Again, a simple two-way valve which let you return to
    either port and starboard tanks.
  3. A real transfer and polishing pump. I used a Jabsco centrifugal pump rated
    at about 250 GPH. Way better than a fuel pump. It's on a timer and runs
    through a set of Racor 1000s.
  4. Separate supply and transfer ports in the tanks. The supply lines exit 6"
    above the bottom of the tank, the transfer ports are located at the very
    bottom. Polishing will catch the gunk long before it gets to the supply ports.
  5. Coast Guard approved fuel hose with JIC fittings. I used Parker hose with
    Parker field-attachable fittings (steel, not brass). This is not cheap,
    usually. I got mine on eBay at about a 80% discount. It's been perfect so
    far. Hydraulic hose will work perfectly well, for less money, but you will
    never be able to use your boat for passengers. Something to consider.
  6. I used Racor 1000s for the main and Racor 500s for the genset and furnace.
    Overkill, but I picked the whole bunch up on eBay for a good price. One word
    of advise, don't forget that the Racors need very special o-ring boss
    connectors.
  7. One last little tip: based on advise from a friend, I put in a bypass
    running from the outlet of the transfer pump to the inlet of the main engine
    filters. By turning on the transfer pump and closing the tank valves, I can
    prime the main engine just by cracking the bleed screw of the secondary
    filter. Works like a charm. I've also added another valve and hose to the
    transfer pump so I can fill jerry cans (I have a diesel in one of my dinghys).
Hope this helps. More details are here:
http://www.islandeagle.net/systems/fuel
Scott Welch
Product Manager, FirstClass Group
"If we continue to take an eye for an eye, then surely the whole world will
go blind." - Gandhi
"Mark Andrew" <msandrew@chartermi.net> writes: >I'm rebuilding an engine room from scratch on a 56' steel trawler (circa >1955). I've spec'd out Racor filters and the ESI polishing system and will >have several manifolds sending fuel from one of assorted fuel tanks to the >various fuel 'users' (main engine, gen set, furnace), and again with their >'return' lines. I've just finished rebuilding a 60 foot trawler, including a complete rewiring and replumbing of the engine room (you can see some pictures at www.islandeagle.net, sadly the website is wayyy out of date). She has a single engine, a single genset, a single heater, and two fuel tanks. You're going to get a bunch of answers to your query, mine might be a bit different. First, I started out with plans much like yours. A supply manifold, a return manifold, the whole nine yards. I then got some advice from a couple of folks I trust a lot, including a commercial ship engineer and a Transport Canada inspector who's also a captain with 35 years of experience. Here are the high points of my system: 1) No supply manifold. I have a single two way valve that lets me select between port and starboard tanks. All consumers are fed from that selection. Dead simple, and it's pretty hard to come up with a real-world example of why you need a more complex system. 2) No return manifold. Again, a simple two-way valve which let you return to either port and starboard tanks. 3) A real transfer and polishing pump. I used a Jabsco centrifugal pump rated at about 250 GPH. Way better than a fuel pump. It's on a timer and runs through a set of Racor 1000s. 4) Separate supply and transfer ports in the tanks. The supply lines exit 6" above the bottom of the tank, the transfer ports are located at the very bottom. Polishing will catch the gunk long before it gets to the supply ports. 5) Coast Guard approved fuel hose with JIC fittings. I used Parker hose with Parker field-attachable fittings (steel, not brass). This is not cheap, usually. I got mine on eBay at about a 80% discount. It's been perfect so far. Hydraulic hose will work perfectly well, for less money, but you will never be able to use your boat for passengers. Something to consider. 6) I used Racor 1000s for the main and Racor 500s for the genset and furnace. Overkill, but I picked the whole bunch up on eBay for a good price. One word of advise, don't forget that the Racors need very special o-ring boss connectors. 6) One last little tip: based on advise from a friend, I put in a bypass running from the outlet of the transfer pump to the inlet of the main engine filters. By turning on the transfer pump and closing the tank valves, I can prime the main engine just by cracking the bleed screw of the secondary filter. Works like a charm. I've also added another valve and hose to the transfer pump so I can fill jerry cans (I have a diesel in one of my dinghys). Hope this helps. More details are here: http://www.islandeagle.net/systems/fuel Scott Welch Product Manager, FirstClass Group "If we continue to take an eye for an eye, then surely the whole world will go blind." - Gandhi
MR
Mark Richter
Thu, Oct 11, 2007 12:21 PM
Mark,
Sounds like quite a project.  Tell us more about the boat when you get the chance.
Copper fuel lines are probably what you want to use.  Steel will rust, and stainless, besides
being pricy, is harder to get a good seal with tube fittings.  Flares take a good bit of skill to
get right, so avoid them and use regular tube fittings that compress on the outside of the tubing
with a soft metal sleeve.  Sure-seal is one good brand, and they are available at McMaster-Carr.
I happen to prefer pipe thread for the other parts, rather than flares, but that's probably just
because I have more experience woth them, and I like to use a teflon pipe-dope on the threads.
What is used on the present fuel system?  Some of the old fittings are probably reuseable, so this
might be a consideration.
Mark Richter, M.E.  trawler-yacht Winnie the Pooh
Mark's Mobile Marine, Electrical system design, installation, repair.
Ortona, FL on  the Okeechobee Waterway
Mark, Sounds like quite a project. Tell us more about the boat when you get the chance. Copper fuel lines are probably what you want to use. Steel will rust, and stainless, besides being pricy, is harder to get a good seal with tube fittings. Flares take a good bit of skill to get right, so avoid them and use regular tube fittings that compress on the outside of the tubing with a soft metal sleeve. Sure-seal is one good brand, and they are available at McMaster-Carr. I happen to prefer pipe thread for the other parts, rather than flares, but that's probably just because I have more experience woth them, and I like to use a teflon pipe-dope on the threads. What is used on the present fuel system? Some of the old fittings are probably reuseable, so this might be a consideration. Mark Richter, M.E. trawler-yacht Winnie the Pooh Mark's Mobile Marine, Electrical system design, installation, repair. Ortona, FL on the Okeechobee Waterway
MA
Mark Andrew
Mon, Oct 15, 2007 8:27 PM
I recently sent the message below...got some great advise.  One person had
followed up with a link to their site where they had a complete schematic of
their fuel system, including their polishing system.  Somehow I misplaced
the message and link.  Could you resend.  I thought I had set it aside to
take a very close look at it, but evidently set it aside too well.
Mark Andrew
"Black River", 56' Steel
Holland, MI
Andrew
Sent: Wednesday, October 10, 2007 1:48 PM
'return' lines.
My question:
connect them with.
Thanks in advance,
Mark
"Black River"
Holland, MI
image001.gif]
I recently sent the message below...got some great advise. One person had followed up with a link to their site where they had a complete schematic of their fuel system, including their polishing system. Somehow I misplaced the message and link. Could you resend. I thought I had set it aside to take a very close look at it, but evidently set it aside too well. Mark Andrew "Black River", 56' Steel Holland, MI -----Original Message----- From: trawlers-and-trawlering-bounces@lists.samurai.com [mailto:trawlers-and-trawlering-bounces@lists.samurai.com] On Behalf Of Mark Andrew Sent: Wednesday, October 10, 2007 1:48 PM To: trawlers-and-trawlering@lists.samurai.com Subject: T&T: Diesel Fuel system design Greetings. This has probably already been covered in years past, but scanning the archives appears to be a chore unless someone would suggest how to do a global search on the various monthly archive files. I'm rebuilding an engine room from scratch on a 56' steel trawler (circa 1955). I've spec'd out Racor filters and the ESI polishing system and will have several manifolds sending fuel from one of assorted fuel tanks to the various fuel 'users' (main engine, gen set, furnace), and again with their 'return' lines. My question: What would be the ideal fittings and hose types I should use? Should I hard pipe the fuel lines, except for the last little length to the engines? If so, should this be in copper, stainless? For fittings, what type do you recommend? Any 'makes' preferred over others? Is 37 SIC preferred over 45 SAE.or something else completely? Are these even the preferred terms? Basically I've got the various items to connect, but need help with what to connect them with. Thanks in advance, Mark "Black River" Holland, MI [demime 1.01d removed an attachment of type image/gif which had a name of image001.gif] _______________________________________________ http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.samurai.com/mailman/options/trawlers-and-trawlering Trawlers & Trawlering and T&T are trademarks of Water World Productions. Unauthorized use is prohibited.
SH
Scott H.E. Welch
Tue, Oct 16, 2007 12:56 PM
That would be me, see http://www.islandeagle.net/systems/fuel
Scott Welch
FirstClass Product Manager
www.firstclass.com
Those who make no mistake rarely make anything.
"Mark Andrew" <msandrew@chartermi.net> writes: >I recently sent the message below...got some great advise. One person had >followed up with a link to their site where they had a complete schematic of >their fuel system, including their polishing system. Somehow I misplaced >the message and link. Could you resend. I thought I had set it aside to >take a very close look at it, but evidently set it aside too well. That would be me, see http://www.islandeagle.net/systems/fuel Scott Welch FirstClass Product Manager www.firstclass.com Those who make no mistake rarely make anything.
MA
Mark Andrew
Wed, Oct 17, 2007 3:29 AM
Greetings Scott, thanks for resending the link to your site.  I've poured
over your schematic to understand your method.  What you did is so close to
what I need to do, that it is very helpful.
A couple differences in our situations, tho.  My boat is 56', a bit shorter
than yours, I assume from the photo.  It used to have a Kahlenberg Diesel
engine 6' tall and 10' long in the engine room (1/3 of the lower deck area).
The engine is now sitting in a marine museum, and was replaced with a Cat
3306 and an added 500 gal fuel tank running fore and aft in the middle of
the engine room.  When we started the renovation, we decided to use half the
original engine room as a master cabin (yes it was that big). We cut off a
couple feet of that 500 gal fuel tank and spun it 90 degrees so it sits
athwarstships now between the two original wing tanks (450 gal each).  That
left a big cavity in the forward end of the engine room for the master cabin
(we had already removed the two old gen sets in the fore of the engine
room).  The original Kahlenberg also ate oil at a tremendous rate, so there
were two 50gal lube oil tanks on one side of the engine room, too.  So this
leads to where our engine room differs..
.the lube oil tanks will now become joined into one 100 gal day tank
(cleanest fuel, next to be burned), the original wing tanks, and the added
(but reduced) "middle" tank for a total of 4 tanks (about 1,400 gal total).
So instead of having a separate T-throw valve to take from either Port or
Starboard tanks as in your scenario, I'm having manifolds made up.  One will
have inputs from all the tanks, and 3 outputs to the engine, gen set,
furnace thru individual Racor 30m filters (the engine getting a dual, like
yours).  The other manifold will have inputs from all the tanks, but then
run to the polishing system thru its 30 micron filter.
For returns, there are again two manifolds, one for the 'users' and another
for the polishing system.
I haven't yet, but need to include a way to transfer fuel to the day tank.
I then plan to most often take from the day tank to the 'users'. (Maybe the
polishing system is a good independent way to transfer from any tank and
return to any other tank [and clean, to boot!], say to move fuel to the day
tank from any tank)
I didn't think of a drain.good idea.
The original Stbd and Port wing tanks have a big 'equalizer' tube between
them, so they fall at the same rate, but valved so they can be isolated, if
necessary.
It appears from your schematic that you use your polishing pump to prime the
'users' filters, and perhaps even to bleed the 'users' when necessary.  Once
you're primed, or bled, do you then throw P1 to close and S1 to open?  Is
that how it works?  Are S1 and your 'priming T' both below the wing tanks in
order to gravity feed after priming?
In my situation, I almost have to put my filters at eye level, so I was
thinking of a small lift pump (Jabsco Junior Gear Puppy, for example) to use
to prime my filters and bleed my 'user' lines. ( I have a follow up question
on this that I'll post separately)
Anyway, these are a few of my thoughts/plans.  If anything jumps out at you
from your experience, feel free to set me straight or have me consider
another alternative.
By the way, nice boat.love the lines.
Mark
From: Scott H.E. Welch [mailto:scott@firstclass.com]
Sent: Tuesday, October 16, 2007 8:57 AM
To: Scott H.E. Welch
Cc: Mark Andrew; trawlers-and-trawlering@lists.samurai.com
Subject: Re: T&T: Diesel Fuel system design
Scott Welch
www.firstclass.com
Greetings Scott, thanks for resending the link to your site. I've poured over your schematic to understand your method. What you did is so close to what I need to do, that it is very helpful. A couple differences in our situations, tho. My boat is 56', a bit shorter than yours, I assume from the photo. It used to have a Kahlenberg Diesel engine 6' tall and 10' long in the engine room (1/3 of the lower deck area). The engine is now sitting in a marine museum, and was replaced with a Cat 3306 and an added 500 gal fuel tank running fore and aft in the middle of the engine room. When we started the renovation, we decided to use half the original engine room as a master cabin (yes it was that big). We cut off a couple feet of that 500 gal fuel tank and spun it 90 degrees so it sits athwarstships now between the two original wing tanks (450 gal each). That left a big cavity in the forward end of the engine room for the master cabin (we had already removed the two old gen sets in the fore of the engine room). The original Kahlenberg also ate oil at a tremendous rate, so there were two 50gal lube oil tanks on one side of the engine room, too. So this leads to where our engine room differs.. .the lube oil tanks will now become joined into one 100 gal day tank (cleanest fuel, next to be burned), the original wing tanks, and the added (but reduced) "middle" tank for a total of 4 tanks (about 1,400 gal total). So instead of having a separate T-throw valve to take from either Port or Starboard tanks as in your scenario, I'm having manifolds made up. One will have inputs from all the tanks, and 3 outputs to the engine, gen set, furnace thru individual Racor 30m filters (the engine getting a dual, like yours). The other manifold will have inputs from all the tanks, but then run to the polishing system thru its 30 micron filter. For returns, there are again two manifolds, one for the 'users' and another for the polishing system. I haven't yet, but need to include a way to transfer fuel to the day tank. I then plan to most often take from the day tank to the 'users'. (Maybe the polishing system is a good independent way to transfer from any tank and return to any other tank [and clean, to boot!], say to move fuel to the day tank from any tank) I didn't think of a drain.good idea. The original Stbd and Port wing tanks have a big 'equalizer' tube between them, so they fall at the same rate, but valved so they can be isolated, if necessary. It appears from your schematic that you use your polishing pump to prime the 'users' filters, and perhaps even to bleed the 'users' when necessary. Once you're primed, or bled, do you then throw P1 to close and S1 to open? Is that how it works? Are S1 and your 'priming T' both below the wing tanks in order to gravity feed after priming? In my situation, I almost have to put my filters at eye level, so I was thinking of a small lift pump (Jabsco Junior Gear Puppy, for example) to use to prime my filters and bleed my 'user' lines. ( I have a follow up question on this that I'll post separately) Anyway, these are a few of my thoughts/plans. If anything jumps out at you from your experience, feel free to set me straight or have me consider another alternative. By the way, nice boat.love the lines. Mark From: Scott H.E. Welch [mailto:scott@firstclass.com] Sent: Tuesday, October 16, 2007 8:57 AM To: Scott H.E. Welch Cc: Mark Andrew; trawlers-and-trawlering@lists.samurai.com Subject: Re: T&T: Diesel Fuel system design "Mark Andrew" <msandrew@chartermi.net> writes: I recently sent the message below...got some great advise. One person had followed up with a link to their site where they had a complete schematic of their fuel system, including their polishing system. Somehow I misplaced the message and link. Could you resend. I thought I had set it aside to take a very close look at it, but evidently set it aside too well. That would be me, see http://www.islandeagle.net/systems/fuel Scott Welch FirstClass Product Manager www.firstclass.com Those who make no mistake rarely make anything.
