View all threadsMATLAB's USRP documentation (e.g. /commusrp/help/methods/sdru_transmitter/comm.sdrutransmitter.step.html) explains the step function as follows:
stepTransmit signal and control data to USRPTM board
Syntaxstep(H,X)
UNDER = step(H,X)
step(H,X,FC)
step(H,X,LO)
step(H,X,GAIN)
step(H,X,INTERP)
Descriptionstep(H,X) transmits signal and control
data to a USRPTM board using User Datagram
Protocol (UDP) packets. The input signal, X, is a
column vector of double values.
What range has X--what are its minimum and maximum values?
Thanks,
Stan
Hi Stan,
The MATLAB code for comm.SDRuTransmitter does not perform any range checking on its inputs. So the object itself will accept any double values.
Any range checking would be performed by the underlying UHD code.
Best,
Mike
Sent: Sunday, March 24, 2013 4:54 PM
To: USRP-USERS Ettus
Cc: Darel Linebarger; Marc Erickson; Ethem Sozer; Mike McLernon
Subject: USRP :: MATLAB's comm.SDRuTransmitter
step
Syntax
step(H,X)
UNDER = step(H,X)
step(H,X,FC)
step(H,X,LO)
step(H,X,GAIN)
step(H,X,INTERP)
Description
step(H,X) transmits signal and control data to a USRPTM board using User Datagram Protocol (UDP) packets. The input signal, X, is a column vector of double values.
Thanks,
Stan
