Can E320 support RFNoC Replay block?
OS
Ofer Saferman
Sat, Jan 9, 2021 6:27 PM
Hello,
Looking at the FPGA code on the repository for E320 I see that the replay
block was previously supported and reverted to a FIFO a few months ago.
Is it not working properly? Can I get a previous version of the FPGA
firmware and use the replay block on a E320?
Regards,
Ofer Saferman
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
Hello, Looking at the FPGA code on the repository for E320 I see that the replay block was previously supported and reverted to a FIFO a few months ago. Is it not working properly? Can I get a previous version of the FPGA firmware and use the replay block on a E320? Regards, Ofer Saferman -- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.
WF
Wade Fife
Tue, Jan 12, 2021 7:13 PM
Hi Ofer,
The Replay block should work fine with E320. It was reverted because the
DMA FIFO was needed in the default image. You can customize and build your
own FPGA images if you need something custom.
Thanks,
Wade
On Sat, Jan 9, 2021 at 12:30 PM Ofer Saferman via USRP-users <
Hello,
Regards,
Ofer Saferman
dangerous content by MailScanner http://www.mailscanner.info/, and is
believed to be clean. _______________________________________________
USRP-users mailing list
USRP-users@lists.ettus.com
Hi Ofer, The Replay block should work fine with E320. It was reverted because the DMA FIFO was needed in the default image. You can customize and build your own FPGA images if you need something custom. Thanks, Wade On Sat, Jan 9, 2021 at 12:30 PM Ofer Saferman via USRP-users < usrp-users@lists.ettus.com> wrote: > Hello, > > Looking at the FPGA code on the repository for E320 I see that the replay > block was previously supported and reverted to a FIFO a few months ago. > Is it not working properly? Can I get a previous version of the FPGA > firmware and use the replay block on a E320? > > Regards, > Ofer Saferman > > -- > This message has been scanned for viruses and > dangerous content by *MailScanner* <http://www.mailscanner.info/>, and is > believed to be clean. _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >
OS
Ofer Saferman
Wed, Jan 13, 2021 4:09 AM
Hello Wade,
Thank you for your reply.
I was going to purchase an E320 only because of the ability to use the
Replay block. Now I can do it without worrying.
Regards,
Ofer Saferman
On Tue, Jan 12, 2021 at 9:13 PM Wade Fife wade.fife@ettus.com wrote:
Hi Ofer,
Thanks,
Wade
Hello,
Regards,
Ofer Saferman
is
Hello Wade, Thank you for your reply. I was going to purchase an E320 only because of the ability to use the Replay block. Now I can do it without worrying. Regards, Ofer Saferman On Tue, Jan 12, 2021 at 9:13 PM Wade Fife <wade.fife@ettus.com> wrote: > Hi Ofer, > > The Replay block should work fine with E320. It was reverted because the > DMA FIFO was needed in the default image. You can customize and build your > own FPGA images if you need something custom. > > Thanks, > > Wade > > On Sat, Jan 9, 2021 at 12:30 PM Ofer Saferman via USRP-users < > usrp-users@lists.ettus.com> wrote: > >> Hello, >> >> Looking at the FPGA code on the repository for E320 I see that the replay >> block was previously supported and reverted to a FIFO a few months ago. >> Is it not working properly? Can I get a previous version of the FPGA >> firmware and use the replay block on a E320? >> >> Regards, >> Ofer Saferman >> >> -- >> This message has been scanned for viruses and >> dangerous content by *MailScanner* <http://www.mailscanner.info/>, and >> is >> believed to be clean. _______________________________________________ >> USRP-users mailing list >> USRP-users@lists.ettus.com >> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >> > -- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.
