conference support for symbian port
R
radha
Mon, Nov 10, 2008 1:19 PM
Hi all,
Is conference support is possible in symbian port of dAudio.
anybody tied this??any help??
Thanks..
Hi all, Is conference support is possible in symbian port of dAudio. anybody tied this??any help?? Thanks..
NI
Nanang Izzuddin
Mon, Nov 10, 2008 2:45 PM
Hi,
The existing samples for Symbian are using conference bridge,
symbian_ua & symbian_ua_gui, so it should be able to do
conference/multiparty as long as you are using low complexity codecs
(e.g. G711, GSM) because of CPU limitation.
nanang
On Mon, Nov 10, 2008 at 8:19 PM, radha radha@solnettechnologies.com wrote:
Hi all,
Thanks..
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Hi, The existing samples for Symbian are using conference bridge, symbian_ua & symbian_ua_gui, so it should be able to do conference/multiparty as long as you are using low complexity codecs (e.g. G711, GSM) because of CPU limitation. Regards, nanang On Mon, Nov 10, 2008 at 8:19 PM, radha <radha@solnettechnologies.com> wrote: > Hi all, > Is conference support is possible in symbian port of dAudio. > anybody tied this??any help?? > > Thanks.. > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > >
R
radha
Tue, Nov 11, 2008 5:42 AM
Hi,
thanks for u'r help. .I will look into this..
To: "pjsip list" pjsip@lists.pjsip.org
Sent: Monday, November 10, 2008 8:15 PM
Subject: Re: [pjsip] conference support for symbian port
Hi,
nanang
wrote:
Hi all,
Thanks..
pjsip mailing list
Hi, thanks for u'r help. .I will look into this.. ----- Original Message ----- From: "Nanang Izzuddin" <nanang@pjsip.org> To: "pjsip list" <pjsip@lists.pjsip.org> Sent: Monday, November 10, 2008 8:15 PM Subject: Re: [pjsip] conference support for symbian port > Hi, > > The existing samples for Symbian are using conference bridge, > symbian_ua & symbian_ua_gui, so it should be able to do > conference/multiparty as long as you are using low complexity codecs > (e.g. G711, GSM) because of CPU limitation. > > Regards, > nanang > > > On Mon, Nov 10, 2008 at 8:19 PM, radha <radha@solnettechnologies.com> > wrote: >> Hi all, >> Is conference support is possible in symbian port of dAudio. >> anybody tied this??any help?? >> >> Thanks.. >> _______________________________________________ >> Visit our blog: http://blog.pjsip.org >> >> pjsip mailing list >> pjsip@lists.pjsip.org >> http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org >> >> > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
