PK
Peter Kriens
Sat, Feb 22, 2025 4:19 PM
I am looking for a way to calculate the 3D path where two shapes are intersecting. In this case, a shape can be limited to a linearly extruded 2D path.
For example:
phi = 45;
union() {
rotate([0,phi,0]) rotate([0,0,45]) cube([20,20,80],center=true);
rotate([0,-phi,0]) cylinder(r=14.2,h=80,center=true);
I would like to have the 3D path indicated in red ...
I am looking for something like:
function intersect( a, b, phi ) = ...
Where an and b are 2D paths of the 2 shapes and phi is 1/2 the intersecting angle for an and b. I understand there are 2, I want the one closes to the XY plane.
I am stuck ... anybody ideas or hints? I am using BOSL2 so any use of the built in functions would be great.
BTW, this is related to ambiguous cylinders https://www.youtube.com/watch?v=sQ-Fsv8vVKo. I want to experiment with different shapes but that requires the formula to be generic.
Kind regards,
Peter Kriens
For example:
phi = 45;
union() {
BTW, this is related to ambiguous cylinders <https://www.youtube.com/watch?v=sQ-Fsv8vVKo>. I want to experiment with different shapes but that requires the formula to be generic.
Kind regards,
Peter Kriens
AM
Adrian Mariano
Sat, Feb 22, 2025 9:03 PM
The code in BOSL2's join_prism() computes this intersection when you give
it to prisms as input, but it isn't exposed to users. Also some recent
tests suggest that this code may have bugs in the case of two arbitrary
linear extrusions.
On Sat, Feb 22, 2025 at 11:20 AM Peter Kriens via Discuss <
2D path.
For example:
phi = 45;
union() {
[image: PastedGraphic-1.png]
Kind regards,
Peter Kriens
To unsubscribe send an email to discuss-leave@lists.openscad.org
linear extrusions.
> 2D path.
> For example:
> phi = 45;
> union() {
> Kind regards,
> Peter Kriens
> _______________________________________________
R
Rudolf
Sun, Feb 23, 2025 12:29 AM
The intersection of a plane with a cylinder is an ellipse. In your
special well-behaved case of phi = 45, and an extruded square shape
intersecting with a circle of same diameter you can scale a circle with
1/sin(phi) and transform it to the intersection plane. This is what my
code shows (but not in a generic way). In the next step you would
describe the parts of the scaled circles you are interested in with a
function and transform it with affine transformations.
However, I would say there is no hope in using OpenSCAD function
language to find the intersection path of arbitrary tilted extruded
shapes, even if the shapes are well-behaved - i.e. their extrusions have
a unique path between your start and end point on the X-axis. If you
tried this you'd be forced to implement complex node search, sort and
calculation algorithms first and you'd encounter a lot of numerical
problems. Much fun.
p = 45;
r = 14.2;
intersection()
rotate([0,p,0]) rotate([0,0,45]) cube([20,20,80],center=true);
rotate([0,-p,0]) cylinder(r=14.2,h=80,center=true);
color("red")
rotate([0, 180-p, 0])
translate([0, 0, r])
rotate([-p, 0, 0])
scale([1, 1/sin(p), 1])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
Am 22.02.2025 um 17:19 schrieb Peter Kriens via Discuss:
extruded 2D path.
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
To unsubscribe send an email todiscuss-leave@lists.openscad.org
problems. Much fun.
p = 45;
r = 14.2;
intersection()
color("red")
rotate([-p, 0, 0])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
> extruded 2D path.
> For example:
> phi = 45;
> union() {
> Kind regards,
> Peter Kriens
AM
Adrian Mariano
Sun, Feb 23, 2025 1:30 AM
Here is an example taken from the BOSL2 manual for join_prism() which works
by computing the intersection between two arbitrary linear extrusions and
then computes a rounding profile along that intersection. Here we have the
flower shaped object as one component and an ellipse shaped object as the
second one. Things will go wrong if the objects aren't well enough
behaved, but the problem is not impossible in OpenSCAD, at least for
reasonable cases.
[image: image.png]
On Sat, Feb 22, 2025 at 7:30 PM Rudolf via Discuss <
The intersection of a plane with a cylinder is an ellipse. In your special
well-behaved case of phi = 45, and an extruded square shape intersecting
with a circle of same diameter you can scale a circle with 1/sin(phi) and
transform it to the intersection plane. This is what my code shows (but not
in a generic way). In the next step you would describe the parts of the
scaled circles you are interested in with a function and transform it with
However, I would say there is no hope in using OpenSCAD function language
to find the intersection path of arbitrary tilted extruded shapes, even if
the shapes are well-behaved - i.e. their extrusions have a unique path
between your start and end point on the X-axis. If you tried this you'd be
forced to implement complex node search, sort and calculation algorithms
first and you'd encounter a lot of numerical problems. Much fun.
p = 45;
r = 14.2;
intersection()
color("red")
rotate([-p, 0, 0])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
2D path.
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
reasonable cases.
[image: image.png]
> p = 45;
> r = 14.2;
> intersection()
> color("red")
> rotate([-p, 0, 0])
> circle(r);
> color("green")
> rotate([0, -p, 0])
> rotate([-p, 0, 0])
> circle(r);
> 2D path.
> For example:
> phi = 45;
> union() {
> Kind regards,
> Peter Kriens
SP
Sanjeev Prabhakar
Sun, Feb 23, 2025 1:54 AM
Here is an example of intersection line between 2 solids and then
manipulating the points to get the kind of line you showed in your sketch
step1:
[image: Screenshot 2025-02-23 at 7.12.26 AM.png]
step2:
[image: Screenshot 2025-02-23 at 7.17.02 AM.png]
step1:
step2:
SP
Sanjeev Prabhakar
Sun, Feb 23, 2025 2:17 AM
but the person in video is probably showing this:
[image: Screenshot 2025-02-23 at 7.45.33 AM.png]
SP
Sanjeev Prabhakar
Sun, Feb 23, 2025 2:37 AM
attached is the scad file generated and the code:
need to add more points for further finer results
from openscad2 import *
a=rot('z45',linear_extrude(pts([[-10,-10],[20,0],[0,20],[-20,0]]),50))
b=o_solid([-1,0,0],circle(14,s=500),50,-25,0,25)
a=rsz3dc(a,[30,40,50])
b=rsz3dc(b,[50,40,30])
l1=ip_sol2sol(a,b,0)
l2=ip_sol2sol(a,b,-1)
l3=l2[:250]+l1[250:]
l3=sec2surface_2(l3)
l4=translate(rot('y45',[-50,0,0]),l3)
sol=rot('y45',solid_from_2surfaces(l3,l4))
with open('trial.scad','w+') as f:
f.write(f'''
{swp(sol)}
f.write(f'''
{swp(sol)}
PK
Peter Kriens
Mon, Feb 24, 2025 8:11 AM
Thanks Rudolf! However, the path I am looking for is 3D, it is not a simple intersection in a plane. It is the z-dimension that makes our eyes believe it happens in the x-y plane.
Peter
On 23 Feb 2025, at 01:29, Rudolf via Discuss discuss@lists.openscad.org wrote:
The intersection of a plane with a cylinder is an ellipse. In your special well-behaved case of phi = 45, and an extruded square shape intersecting with a circle of same diameter you can scale a circle with 1/sin(phi) and transform it to the intersection plane. This is what my code shows (but not in a generic way). In the next step you would describe the parts of the scaled circles you are interested in with a function and transform it with affine transformations.
However, I would say there is no hope in using OpenSCAD function language to find the intersection path of arbitrary tilted extruded shapes, even if the shapes are well-behaved - i.e. their extrusions have a unique path between your start and end point on the X-axis. If you tried this you'd be forced to implement complex node search, sort and calculation algorithms first and you'd encounter a lot of numerical problems. Much fun.
p = 45;
r = 14.2;
intersection()
color("red")
rotate([-p, 0, 0])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
<cTt6ag6v39Bm6Wyp.png>
For example:
phi = 45;
union() {
<PastedGraphic-1.png>
Kind regards,
Peter Kriens
To unsubscribe send an email to discuss-leave@lists.openscad.org mailto:discuss-leave@lists.openscad.org
Peter
> On 23 Feb 2025, at 01:29, Rudolf via Discuss <discuss@lists.openscad.org> wrote:
> p = 45;
> r = 14.2;
> intersection()
> color("red")
> rotate([-p, 0, 0])
> circle(r);
> color("green")
> rotate([0, -p, 0])
> rotate([-p, 0, 0])
> circle(r);
>> For example:
>> phi = 45;
>> union() {
>> Kind regards,
>> Peter Kriens
>> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>
PK
Peter Kriens
Mon, Feb 24, 2025 8:14 AM
Yes, that is the shape. Thanks.
You are enticing me more and more to try out your environment. Just an old dislike of python that is hard for me to get over ... then again. The Openscad language is actually much worse in the aspects I dislike in Python ... so maybe for a next project.
Peter
On 23 Feb 2025, at 02:54, Sanjeev Prabhakar sprabhakar2006@gmail.com wrote:
Here is an example of intersection line between 2 solids and then manipulating the points to get the kind of line you showed in your sketch
step1:
<Screenshot 2025-02-23 at 7.12.26 AM.png>
step2:
<Screenshot 2025-02-23 at 7.17.02 AM.png>
Peter
> On 23 Feb 2025, at 02:54, Sanjeev Prabhakar <sprabhakar2006@gmail.com> wrote:
> step1:
> step2:
PK
Peter Kriens
Mon, Feb 24, 2025 8:40 AM
I love join_prism! Gonna give this a try.
Peter
Can you give me an example how I could get this intersection path?
On 23 Feb 2025, at 02:30, Adrian Mariano via Discuss discuss@lists.openscad.org wrote:
Here is an example taken from the BOSL2 manual for join_prism() which works by computing the intersection between two arbitrary linear extrusions and then computes a rounding profile along that intersection. Here we have the flower shaped object as one component and an ellipse shaped object as the second one. Things will go wrong if the objects aren't well enough behaved, but the problem is not impossible in OpenSCAD, at least for reasonable cases.
<image.png>
On Sat, Feb 22, 2025 at 7:30 PM Rudolf via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
p = 45;
r = 14.2;
intersection()
color("red")
rotate([-p, 0, 0])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
Peter
> On 23 Feb 2025, at 02:30, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote:
> <image.png>
> On Sat, Feb 22, 2025 at 7:30 PM Rudolf via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote:
>> p = 45;
>> r = 14.2;
>> intersection()
>> color("red")
>> rotate([-p, 0, 0])
>> circle(r);
>> color("green")
>> rotate([0, -p, 0])
>> rotate([-p, 0, 0])
>> circle(r);
>>> For example:
>>> phi = 45;
>>> union() {
>>> Kind regards,
>>> Peter Kriens
R
Rudolf
Mon, Feb 24, 2025 4:43 PM
Well I think, I'd rather try to construct the solution first. Don't know
what exactly you are heading for, but it is rather straight forward to
construct a linearly extruded object bounded by the the path you are
looking for. E.g. a cylinder cut by a 6-star at an angle of 35°. This
is a union of the hull of a difference and some mirrored stuff of the
diff of diff of the same. If one of the objects is not symmetrical,
things get a bit more difficult, but it works.
However the use of hull restricts the solution to convex objects. Maybe
this can help.
Am 24.02.2025 um 09:11 schrieb Peter Kriens via Discuss:
Peter
p = 45;
r = 14.2;
intersection()
color("red")
rotate([-p, 0, 0])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
extruded 2D path.
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
this can help.
> Peter
>> p = 45;
>> r = 14.2;
>> intersection()
>> color("red")
>> rotate([-p, 0, 0])
>> circle(r);
>> color("green")
>> rotate([0, -p, 0])
>> rotate([-p, 0, 0])
>> circle(r);
>>> extruded 2D path.
>>> For example:
>>> phi = 45;
>>> union() {
>>> Kind regards,
>>> Peter Kriens
PK
Peter Kriens
Mon, Feb 24, 2025 5:04 PM
I wanted to have the path of the intersecting shapes because that path needs to be extruded in the z direction (assuming shapes are at 45 degree). Since the intersecting path is 3D, the top of that extrusion must also follow the z values.
This is the original paper about the issue: https://www.cs.jhu.edu/~misha/ReadingSeminar/Papers/Sugihara18.pdf
Thanks,
Peter
On 24 Feb 2025, at 17:43, Rudolf via Discuss discuss@lists.openscad.org wrote:
Well I think, I'd rather try to construct the solution first. Don't know what exactly you are heading for, but it is rather straight forward to construct a linearly extruded object bounded by the the path you are looking for. E.g. a cylinder cut by a 6-star at an angle of 35°. This is a union of the hull of a difference and some mirrored stuff of the diff of diff of the same. If one of the objects is not symmetrical, things get a bit more difficult, but it works.
However the use of hull restricts the solution to convex objects. Maybe this can help.
<gPoGVbEHdcgtHc2U.png> <V10j8Cs1v555X8kH.png>
Peter
On 23 Feb 2025, at 01:29, Rudolf via Discuss discuss@lists.openscad.org mailto:discuss@lists.openscad.org wrote:
p = 45;
r = 14.2;
intersection()
color("red")
rotate([-p, 0, 0])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
Thanks,
Peter
> On 24 Feb 2025, at 17:43, Rudolf via Discuss <discuss@lists.openscad.org> wrote:
>> Peter
>>> On 23 Feb 2025, at 01:29, Rudolf via Discuss <discuss@lists.openscad.org> <mailto:discuss@lists.openscad.org> wrote:
>>> p = 45;
>>> r = 14.2;
>>> intersection()
>>> color("red")
>>> rotate([-p, 0, 0])
>>> circle(r);
>>> color("green")
>>> rotate([0, -p, 0])
>>> rotate([-p, 0, 0])
>>> circle(r);
>>>> For example:
>>>> phi = 45;
>>>> union() {
>>>> Kind regards,
>>>> Peter Kriens
R
Rudolf
Tue, Feb 25, 2025 12:09 AM
Nice problem. challenging approach. Yeah, needs a lot of math. I tried
to model Figure 18 to get a feeling for the difficult parts and saw at
least how it works, and that the main challenge is that the "cheating
surfaces" do have two faces defined by three 3D-lines.
Well, the shading in OpenSCADs viewport is a bit missleading, but I
think it is visible that upper surfaces of the cheating bits need a
proper calculation to make the Illusion perfect for both views ...
Am 24.02.2025 um 18:04 schrieb Peter Kriens via Discuss:
Thanks,
Peter
Peter
p = 45;
r = 14.2;
intersection()
color("red")
rotate([-p, 0, 0])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
For example:
phi = 45;
union() {
be generic.
Kind regards,
Peter Kriens
> Thanks,
> Peter
>>> Peter
>>>> p = 45;
>>>> r = 14.2;
>>>> intersection()
>>>> color("red")
>>>> rotate([-p, 0, 0])
>>>> circle(r);
>>>> color("green")
>>>> rotate([0, -p, 0])
>>>> rotate([-p, 0, 0])
>>>> circle(r);
>>>>> For example:
>>>>> phi = 45;
>>>>> union() {
>>>>> be generic.
>>>>> Kind regards,
>>>>> Peter Kriens
RW
Raymond West
Tue, Feb 25, 2025 3:34 PM
Is this the sort of 'path' you were looking for?
$fn=100;
s=50;// side
d=s*sqrt(2);
t=2.1; //'thickness' of line
intersection(){
rotate([0,0,45])
difference(){
cube ([s,s,s4],true);
cube([s-t,s-t,s4],true);
translate([-s2,0,0])
rotate([0,90,0])
difference(){
cylinder(d=d,h=d3);
cylinder(d=d-t,h=d^3);
if it is for your specific curve, then difference it with some cubes,
say, (or maybe intersect) to select the parts you want, rotate and
extrude in whatever direction you desire.
If you want a generic solution, using polygons points (the polygons
being in different planes) that is quite doable, but then you will want
instead of intersections on planes, intersection of polyhedrons on faces
of an intermediate polyhedron. (As yet, I have not bothered to refer to
the mentioned paper.)
Thanks,
Peter
Peter
p = 45;
r = 14.2;
intersection()
color("red")
rotate([-p, 0, 0])
circle(r);
color("green")
rotate([0, -p, 0])
rotate([-p, 0, 0])
circle(r);
For example:
phi = 45;
union() {
be generic.
Kind regards,
Peter Kriens
$fn=100;
s=50;// side
d=s*sqrt(2);
intersection(){
rotate([0,0,45])
difference(){
cube ([s,s,s*4],true);
cube([s-t,s-t,s*4],true);
translate([-s*2,0,0])
rotate([0,90,0])
difference(){
cylinder(d=d,h=d*3);
> Thanks,
> Peter
>>> Peter
>>>> p = 45;
>>>> r = 14.2;
>>>> intersection()
>>>> color("red")
>>>> rotate([-p, 0, 0])
>>>> circle(r);
>>>> color("green")
>>>> rotate([0, -p, 0])
>>>> rotate([-p, 0, 0])
>>>> circle(r);
>>>>> For example:
>>>>> phi = 45;
>>>>> union() {
>>>>> be generic.
>>>>> Kind regards,
>>>>> Peter Kriens
R
Rudolf
Thu, Feb 27, 2025 9:28 PM
Hi Peter,
Adrian was right, it is not such a big drama to compute the intersection
point of two extruded shapes, as long as they are somehow
"well-behaved". I extracted the relevant functions and modules from my
libraries and wrote your function intersect(shape1, shape2, w1, w2)
and some test stuff with generic OpenSCAD. Find the scad file attached.
The code is indeed quite neat and easy to understand. It computes the
affine intersection of freely translated and rotated 2D-shapes, which
are assumed to be endless in both directions.
The function calculates all planes of the faces that delimit shape2,
intersects each with all lines of shape1 and collects and returns only
those points that are situated on a face This means, two function calls
are needed to get hands on all intersection points. I leave it up to you
to sort the sets together. In most cases you will be fine just using the
richer set.
I didn't have the time to protect the code against instabilities, mostly
singularities from the dot product of two parallel vectors. As usual in
OpenSCAD tiny-angle rotations or tiny-value translations get you around,
as shown in the test code that produced the second example.
Hope this helps you along. I'm curious whether it will bring you forward
with the topology stuff in the paper.
Rudolf
// intersect two 2D shapes at an angle w
function intersect(Sh1, Sh2, w1=w1, w2=w2) =
let(Sh1 = Rx(w1, Sh1), Sh2 = Rx(w2, Sh2))
let(N1 = Rx(w1, [0,0,1]), N2 = Rx(w2, [0,0,1]))
let(L1 = len(Sh1), L2=len(Sh2))
let(sign = L1<L2)
let(result =
for(i = [0:L2-1], j = [0:L1-1])
// define the current face of Sh2
let(P1 = Sh2[i], P2=Sh2[(i+1)%L2])
let(P3 = P1+N2, P4 = P2+N2)
let(d = norm(P1-P2))
// calc the intersection of all lines of Sh1 with current face of Sh2
let(A = Sh1[j], B = A+N1)
let(I = line_plane_intersection(A, B, P1, P2, P3))
let(dist1 = distance_point_to_line(P1, P3, I))
let(dist2 = distance_point_to_line(P2, P4, I))
// filter points that closely touch the face
if(dist1+dist2<=d*1.0001)
I
result;
extruded 2D path.
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
Hi Peter,
libraries and wrote your function *intersect(shape1, shape2, w1, w2)*
richer set.
Rudolf
let(sign = L1<L2)
let(result =
I
result;
> extruded 2D path.
> For example:
> phi = 45;
> union() {
> Kind regards,
> Peter Kriens
PK
Peter Kriens
Wed, Mar 5, 2025 10:36 AM
I think I got the ambiguous cylinder to work ... more or less. The code from Rudolf was extremely helpful and taught me a lot about Openscad code. Thanks again. :-)
To start, a final result, viewed from both sides. Note the little hole, if you can see the hole on the other side, you're on the right angle.
The code Rudolf gave me resulted in the intersection path. However, this path is by its nature ambiguous (pun not intended). Rudolf used an algorithm to intersect each point in the two paths with the other shape. That can give multiple intersection.
What I needed, however, was the bottom of one side and the top of the other side of this 3D path. To be honest, I was ready to give up. However, when I looked on this path from the Z view, I noticed this:
Removing the points on the inside of this shape seems easier than decomposing the 3D path in its constituents. However, my expertise wasn't sufficient to write that code. Chat GPT gave me a function that used the area of the polygon. If you could remove a point of the path without changing its area it is safe to remove that point. However, I could not get this to work well. Looking at BOSL2 I thought union() might work but it didn't, even after I used a function to split it in multiple polygons. Then I found hull2D_path(). Disadvantage is that it uses hulling and that works only for convex shapes but my suspicion is that for this problem that is not a big issue. However, this seems such a common problem that it surprises me I could not find anything in BOSL2 that would do this cleanup for me? Anyway, after the hull2D_path I got:
After some confusion on my side, I realized that hull2D_path() returns indexes of the orinal path, not a new path. This turned out to be really useful since the 3D path from Rudolph for the top used exactly the same indexes! Using this index list, it was trivial to extract the top 3D points that formed its outline. So now I had a bottom (the 2D path) and a top (the 3D path). The 2D path was easy to convert to 3D with z=0.
These could now be given to skin():
Since the bottom 2D path was perfectly aligned with the top path, this works quite well. To remove the inside of the resulting shape, I offset the 2D bottom path to be a bit smaller and then used difference to remove it from the skinned part:
Along the way I had a scaffold to see what I was doing:
The shape functions are very sensitive to the shapes that are used and I usually get a 'non planar' image. The main issue during construction is with an assert in the line intersection algorithm, It says that lines are parallel (and this not intersect) and then gives up. I intuit this probably can be fixed. Clearly there are some constraints on the shapes. I probably could improve on this but time ran out ...
Feedback how to improve this are welcome.
Peter Kriens
On 27 Feb 2025, at 22:28, Rudolf via Discuss discuss@lists.openscad.org wrote:
Hi Peter,
Adrian was right, it is not such a big drama to compute the intersection point of two extruded shapes, as long as they are somehow "well-behaved". I extracted the relevant functions and modules from my libraries and wrote your function intersect(shape1, shape2, w1, w2) and some test stuff with generic OpenSCAD. Find the scad file attached. The code is indeed quite neat and easy to understand. It computes the affine intersection of freely translated and rotated 2D-shapes, which are assumed to be endless in both directions.
The function calculates all planes of the faces that delimit shape2, intersects each with all lines of shape1 and collects and returns only those points that are situated on a face This means, two function calls are needed to get hands on all intersection points. I leave it up to you to sort the sets together. In most cases you will be fine just using the richer set.
I didn't have the time to protect the code against instabilities, mostly singularities from the dot product of two parallel vectors. As usual in OpenSCAD tiny-angle rotations or tiny-value translations get you around, as shown in the test code that produced the second example.
Hope this helps you along. I'm curious whether it will bring you forward with the topology stuff in the paper.
Rudolf
let(sign = L1<L2)
let(result =
I
result;
<nGpKKGbcKaEzok3B.png>
<ZcA2AgZ5byJR3asr.png>
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
Peter Kriens
> On 27 Feb 2025, at 22:28, Rudolf via Discuss <discuss@lists.openscad.org> wrote:
> Hi Peter,
> Rudolf
> let(sign = L1<L2)
> let(result =
> I
> result;
>> For example:
>> phi = 45;
>> union() {
>> Kind regards,
>> Peter Kriens
> <intersection.scad>_______________________________________________
GS
Guenther Sohler
Wed, Mar 5, 2025 10:53 AM
In PythonSCAD (and potentially soon in OpenSCAD) you could
- output mesh on Object A and create a list of edges
- output mesh on Object B and create a list of edges
- union/difference Object A with B , output mesh and create list of edges
- select Set of Edges from 3 which are neither in included in 1) nor 2)
- sum up the lengths of Edges from 4)
my little 2 cents. I use exactly that algorithm for filling the cut line of
2 objects
On Thu, Feb 27, 2025 at 10:28 PM Rudolf via Discuss <
Hi Peter,
both directions.
richer set.
Rudolf
let(sign = L1<L2)
let(result =
I
result;
2D path.
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
1) output mesh on Object A and create a list of edges
2) output mesh on Object B and create a list of edges
3) union/difference Object A with B , output mesh and create list of edges
4) select Set of Edges from 3 which are neither in included in 1) nor 2)
5) sum up the lengths of Edges from 4)
2 objects
> Hi Peter,
> your function *intersect(shape1, shape2, w1, w2)* and some test stuff
> both directions.
> richer set.
> Rudolf
> let(sign = L1<L2)
> let(result =
> I
> result;
> 2D path.
> For example:
> phi = 45;
> union() {
> Kind regards,
> Peter Kriens
PK
Peter Kriens
Fri, Mar 7, 2025 8:21 AM
I am having one more problem and I can't seem to find a good solution.
I have a closed 3D path. How do I make this into a wall that descents to the z=0? The problem is that the top must have the Z-variances so extrudes seem out of the questions. I want the top of the wall to be flat and be able to parameterize its overall thickness (the current algorithm that uses difference() can create very steep walls when angles are high.)
Is there any function in BOSL2 that can do this?
Peter
On 5 Mar 2025, at 11:53, Guenther Sohler via Discuss discuss@lists.openscad.org wrote:
my little 2 cents. I use exactly that algorithm for filling the cut line of 2 objects
On Thu, Feb 27, 2025 at 10:28 PM Rudolf via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
Hi Peter,
Rudolf
let(sign = L1<L2)
let(result =
I
result;
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
Peter
> On 5 Mar 2025, at 11:53, Guenther Sohler via Discuss <discuss@lists.openscad.org> wrote:
> On Thu, Feb 27, 2025 at 10:28 PM Rudolf via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote:
>> Hi Peter,
>> Rudolf
>> let(sign = L1<L2)
>> let(result =
>> I
>> result;
>>> For example:
>>> phi = 45;
>>> union() {
>>> Kind regards,
>>> Peter Kriens
R
Rudolf
Fri, Mar 7, 2025 9:31 AM
not perfect, but I think viable in your case: you can calculate scalex,
scaley values for the 2D shape that keeps the wall thickness at least at
X and Y axis. Scaling only X,Y coordinates provides you an inner shape
with the same number of points and lets you build a sequence of squares
in the second step which you can use to do a circular extrude around Z
instead of linear extruding along Z.
Am 07.03.2025 um 09:21 schrieb Peter Kriens via Discuss:
angles are high.)
Peter
edges
nor 2)
line of 2 objects
Hi Peter,
*intersect(shape1, shape2, w1, w2)* and some test stuff with
Rudolf
let(sign = L1<L2)
let(result =
face of Sh2
I
result;
For example:
phi = 45;
union() {
to be generic.
Kind regards,
Peter Kriens
> angles are high.)
> Peter
>> edges
>> nor 2)
>> line of 2 objects
>> Hi Peter,
>> Rudolf
>> let(sign = L1<L2)
>> let(result =
>> face of Sh2
>> I
>> result;
>>> For example:
>>> phi = 45;
>>> union() {
>>> to be generic.
>>> Kind regards,
>>> Peter Kriens
DP
Dan Perry
Fri, Mar 7, 2025 10:13 AM
This would be my solution:
- Take the x-y values from your 3d path as the exterior of the solution.
- Use offset() to create the interior. offset(exterior,
delta=-wall_thickness, closed=true);
- Difference() 2 from 1 and linear_extrude() to max z-height.
- Take the x-z values from your 3d path, linear_extrude, rotate and
translate it, then difference() it to cut the top to your desired shape.
Dan
On Fri, Mar 7, 2025 at 8:21 AM Peter Kriens via Discuss <
[image: PastedGraphic-7.png][image: PastedGraphic-9.png]
Peter
of 2 objects
Hi Peter,
both directions.
richer set.
Rudolf
let(sign = L1<L2)
let(result =
I
result;
2D path.
For example:
phi = 45;
union() {
Kind regards,
Peter Kriens
1. Take the x-y values from your 3d path as the exterior of the solution.
2. Use offset() to create the interior. offset(exterior,
3. Difference() 2 from 1 and linear_extrude() to max z-height.
4. Take the x-z values from your 3d path, linear_extrude, rotate and
Dan
> Peter
> of 2 objects
>> Hi Peter,
>> both directions.
>> richer set.
>> Rudolf
>> let(sign = L1<L2)
>> let(result =
>> I
>> result;
>> 2D path.
>> For example:
>> phi = 45;
>> union() {
>> Kind regards,
>> Peter Kriens
