If you do a Google translate on the page, he actually states that there are
silicon diodes there.
Rob K
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On
Behalf Of Daun Yeagley
Sent: 08 May 2007 17:41
To: daun@yeagley.net; 'Discussion of precise time and frequency measurement'
Subject: Re: [time-nuts] NTP Synchronised Nixie Tube Clock
Here's the evidence.
Daun
Sent: Tuesday, May 08, 2007 12:35 PM
To: 'Discussion of precise time and frequency measurement'
Ah, but I saw some glass semiconductor diodes in there! Look about half way
down the page. Could they be 1N914's? (I don't do German)
Daun
Behalf Of Maggie Leber
Sent: Tuesday, May 08, 2007 12:02 PM
To: Discussion of precise time and frequency measurement
On 5/8/07, Jason Rabel jason@extremeoverclocking.com wrote:
Lol, as I was reading the posts I was thinking, "I bet Tom hooked one
up to his Maser"....
And sure enough the proof is in the pictures. ;)
You guys crack me up.
Of course, a truly hard-core Nixie tube clock wouldn't use semiconductors at
all.
http://www.jogis-roehrenbude.de/Leserbriefe/Bruegmann-Digital-Roehren-Clock/
Digi
tal-Roehrenuhr.htm
(or http://tinyurl.com/3632h )
http://www.eldocountry.com/projects/tubeclock.html
73 de Maggie K3XS
Editor, Phil-Mont Mobile Radio Club Blurb - http://www.phil-mont.org
Elecraft K2 #1641 -- AOPA 925383 -- ARRL 39280
time-nuts mailing list
Perhaps my "hard core" requirement should be restated as "no
transistors" rather than "no semiconductors". :-)
73 de Maggie K3XS
Hello,
as I do not have problems with this strange lange, I hope I can help finding the answer ;-)
According the description, not having started with a ready overall design the developper Friedhelm Bruegmann did work 7 years on it!
He did start, because he had the idea to bring all his collected valves into practical use after a long period of collection.
A lot of appearing technical problems had to be solved then. Therefore it was not possible to have a clear idea about the power needed for this project, which finally gave him some headaches. Though theoretically
possible to avoid all semiconductors totally, the transformers of choice turned out to be too small. As there are already 103 vacuum tubes in use, just the heater current levelled up to 39A! But, as at the time of digital
breakthrough semiconducter diodes were already in mixed use with VTs, Friedhelm did not see a breach of style to use SC-diodes. He applied 4xBY227, 66xBA157, 72x1N4148. All these parts are clearly shown in the
diagrams and mentioned in the description. I stopped thinking about the bigger size of chassis he would have needed.
Anyway, a outstanding development!
Beside, did ENIAC use any semiconducters?
The run-up you can watch here:
http://www.jogis-roehrenbude.de/Leserbriefe/Bruegmann-Digital-Roehren-Clock/mov002.zip
The set-back is shown here:
http://www.jogis-roehrenbude.de/Leserbriefe/Bruegmann-Digital-Roehren-Clock/mov003.zip
The total schematic:
http://www.jogis-roehrenbude.de/Leserbriefe/Bruegmann-Digital-Roehren-Clock/sheet001.pdf
greetings,
Arnold, DK2WT
Daun
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf
Of Maggie Leber
Lol, as I was reading the posts I was thinking, "I bet Tom hooked one up to
his Maser"....
semiconductors at all.
73 de Maggie K3XS
In that case, I guess my clock also qualifies: it uses neon lamps
as its "active" components.
The only semiconductors used are simple diodes and two blue LEDs.
See http://wwwhome.cs.utwente.nl/~ptdeboer/ham/neonclock/ .
73, Pieter-Tjerk, PA3FWM
Yeah, if I did something like this:
http://www.eldocountry.com/projects/tubeclock/tube2lrg.jpg
There would be a large bonfire on my table! I'm amazed he didn't short
something out!
Jason
Well, mine is not NTP or GPS controlled (unless the PC is), but it has a
lot of bells and whistles :-)
http://www.ko4bb.com/ham_radio/Clock
(free download, no charge even for the bugs, er... unexpected features)
Didier KO4BB
Bill Hawkins wrote:
Well, I've been using the virtual Nixie clock from JagAir at
http://www.clockvault.com/nixie.htm
No hardware to fail, choice of display tubes, but it only runs
on Windows. The software is free. I'm a satisfied user, with no
commercial interest. There is other good stuff at the site.
Bill Hawkins
I find it humorous, that at the bottom of that page it says: "Last
Updated: January 1, 1970 GMT"
At 06:49 PM 5/8/2007, Didier Juges wrote...
a
It does sound funny. Unfortunately, it seems like it may be your
configuration.
The page uses Javascript to instruct the browser to fetch the document
updated time stamp. It seems like your browser does not handle
Javascript the way it's intended. The way it's supposed to work: the
Javascript instructs the browser to fetch the document's time stamp and
render it on the page. The browser is either ignoring the request and
putting some default value, or it does not fetch it properly and fails
to convert the date to a proper text string.
Try another browser, here it looks fine (the page was updated earlier today)
I use Firefox under XP Pro, I have not tried others.
Didier KO4BB
Now that's a thing of beauty!!!! It just went on my list of things to have
before I die!!! :)
Sent: Tuesday, May 08, 2007 11:02 AM
Digital-Roehrenuhr.htm
73 de Maggie K3XS
No kidding. That clock would be equally at home in "Blade Runner" or
"Triumph des Willens."
-- john, KE5FX
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com]On
Behalf Of Jack Hudler
Sent: Tuesday, May 08, 2007 5:37 PM
before I die!!! :)
