ctbirds@lists.ctbirding.org
For discussing birds and birding in Connecticut
CTWA - 10 days
ED
Edward Dettore
Thu, Sep 27, 2012 1:13 AM
After comparing the photo I took on the 16th with the ones I took on the 25th, and with the ones Joseph Cala posted, it appears to be the same bird. When looking at the right side of the bird, you can see a mark in the eye ring at the 9:00 position. I know this isn't definitive, but, it is probably more likely than 2 CTWAs stopping at the same spot. I know warblers stop to, "load up", for a few days, when migrating; but, is 10 days too long?
By the way, Jonah Cohen, it was me you met tonight at the marsh, sorry for not introducing myself, I can be a birdbrain sometimes (pun intended). I have seen a Blackpoll Warbler for several days now, including tonight. I haven't seen the Blackburnian, someone else had seen one a day or two agao.
The pics of the CTWA are linked below, 1 from the 16th, and 1 from the 25th.
https://plus.google.com/u/0/photos/107605353618421013589/albums/5727665918721749121/5788829109644335298
https://plus.google.com/u/0/photos/107605353618421013589/albums/5727665918721749121/5792655553096849410
Ed Dettore
After comparing the photo I took on the 16th with the ones I took on the 25th, and with the ones Joseph Cala posted, it appears to be the same bird. When looking at the right side of the bird, you can see a mark in the eye ring at the 9:00 position. I know this isn't definitive, but, it is probably more likely than 2 CTWAs stopping at the same spot. I know warblers stop to, "load up", for a few days, when migrating; but, is 10 days too long? By the way, Jonah Cohen, it was me you met tonight at the marsh, sorry for not introducing myself, I can be a birdbrain sometimes (pun intended). I have seen a Blackpoll Warbler for several days now, including tonight. I haven't seen the Blackburnian, someone else had seen one a day or two agao. The pics of the CTWA are linked below, 1 from the 16th, and 1 from the 25th. https://plus.google.com/u/0/photos/107605353618421013589/albums/5727665918721749121/5788829109644335298 https://plus.google.com/u/0/photos/107605353618421013589/albums/5727665918721749121/5792655553096849410 Ed Dettore
