RK
Roland Klabunde
Sat, Nov 10, 2007 2:50 PM
M:/pj-sip/pjlib/src/pj/os_core_win32.c:134: undefined reference to
WSAStartup@8' M:/pj-sip/pjlib/src/pj/os_core_win32.c:135: undefined reference to WSAGetLastError@0'
WSAGetLastError@0' M:/pj-sip/pjlib/src/pj/os_core_win32.c:135: undefined reference to WSAGetLastError@0'
You need to link the winsocket library.
From: "Eagle I Martin Baranski" eagle3386@googlemail.com
To: "pjsip embedded/DSP SIP discussion" pjsip@lists.pjsip.org
Sent: Saturday, November 10, 2007 3:05 PM
Subject: Re: [pjsip] Win32 build doesn't build because of stddef.h
Excellent!
Now we know the name of pjlib file on disk. That name will need to be
referenced on applications that use pjlib.
Next, try to build pjlib-test. If it complains of unreferenced stuff
put the pjlib already build as -l.
Thanks! :)
Yes, it complains about unreferenced stuff.. Therefore, I've added
"-lM:\pj-sip\pjlib\lib\libpjlib-i386-win32-vc8-debug.a" to the
linker's options, but that didn't solve the problem (even just adding
"-llibpjlib-i386-win32-vc8-debug.a" didn't help.. Full error:
[100.0%] mingw32-gcc.exe -LC:\MinGW\lib
-LC:\MinGW\lib\gcc\mingw32\3.4.5 -o
..\bin\pjlib-test-i386-win32-vc8-debug.exe
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\atomic.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\echo_clt.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\errno.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\exception.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\fifobuf.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\file.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\ioq_perf.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\ioq_tcp.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\ioq_udp.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\ioq_unreg.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\list.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\main.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\mutex.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\os.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\pool.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\pool_perf.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\rand.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\rbtree.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\select.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\sleep.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\sock.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\sock_perf.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\string.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\test.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\thread.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\timer.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\timestamp.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\udp_echo_srv_ioqueue.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\udp_echo_srv_sync.o
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\util.o
-lM:\pj-sip\pjlib\lib\libpjlib-i386-win32-vc8-debug.a -s -lnetapi32
-lmswsock -lws2_32 -lodbc32 -lodbccp32 -loleaut32 -lole32
C:\MinGW\bin..\lib\gcc\mingw32\3.4.5........\mingw32\bin\ld.exe:
cannot find -lM:\pj-sip\pjlib\lib\libpjlib-i386-win32-vc8-debug.a
collect2: ld returned 1 exit status
Process terminated with status 1 (0 minutes, 8 seconds)
1 errors, 0 warnings
Did I miss something? - Since I want to fix as much stuff as possible
by my own, I played a bit around with the linker's settings (there's
list with libraries at the left and a textarea for entering custom
options at the right - the "-l"-stuff goes into that textarea) and
added the "libpjlib-i386-win32-vc8-debug.a"-file to the list at the
left - that seemed to work a bit better, but I then got this:
output\pjlib-test-i386-win32-vc8-debug\src\pjlib-test\util.o -s
-lnetapi32 -lmswsock -lws2_32 -lodbc32 -lodbccp32 -loleaut32 -lole32
M:\pj-sip\pjlib\lib\libpjlib-i386-win32-vc8-debug.a(os_core_win32.o):
In function pj_init': M:/pj-sip/pjlib/src/pj/os_core_win32.c:134: undefined reference to WSAStartup@8'
`WSAGetLastError@0'
So, although there's no "-l" before the absolute path to the
pjlib-file, it seems to work, because the linker doesn't complain
about "file not found"..
= ~ Code is poetry ~
Visit our blog: http://blog.pjsip.org
pjsip mailing list
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
`WSAStartup@8'
`WSAGetLastError@0'
`WSAGetLastError@0'
`WSAGetLastError@0'
From: "Eagle I Martin Baranski" <eagle3386@googlemail.com>
To: "pjsip embedded/DSP SIP discussion" <pjsip@lists.pjsip.org>
> 2007/11/10, perry@pjsip.org <perry@pjsip.org>:
>> Excellent!
> Thanks! :)
> C:\MinGW\bin\..\lib\gcc\mingw32\3.4.5\..\..\..\..\mingw32\bin\ld.exe:
> In function `pj_init':
> `WSAStartup@8'
> `WSAGetLastError@0'
> `WSAGetLastError@0'
> `WSAGetLastError@0'
> = Martin Baranski
> = Eagle | Eagle3386
> = www.troublezone.net
> = eagle3386@gmail.com
> = +49 (0)160 93317843
> _______________________________________________
> pjsip mailing list
EI
Sat, Nov 10, 2007 7:34 PM
I thought that is linked by "mswsock"? - Because that one is already linked:
2007/11/10, Roland Klabunde <roland.klabunde@freenet.de>:
> `WSAStartup@8'
> `WSAGetLastError@0'
> `WSAGetLastError@0'
> `WSAGetLastError@0'
= Martin Baranski
= Eagle | Eagle3386
RK
Roland Klabunde
Sat, Nov 10, 2007 7:48 PM
Note the namings. Obviously your lib cannot resolve the functions.
Sent: Saturday, November 10, 2007 8:34 PM
>> `WSAStartup@8'
>> `WSAGetLastError@0'
>> `WSAGetLastError@0'
>> `WSAGetLastError@0'
> linked:
> = Martin Baranski
> = Eagle | Eagle3386
> pjsip mailing list
L
logan
Sat, Nov 10, 2007 8:05 PM
Hi,
Try wsock32.lib, look for it on your disk and include the path in your
linker directories. If you can't find it then it's available with the MS
Platform SDK.
Thanks.
Best Regards,
Hitesh
Sent: Sunday, November 11, 2007 1:04 AM
Hi,
Platform SDK.
Thanks.
Best Regards,
Hitesh
>> `WSAStartup@8'
>> `WSAGetLastError@0'
>> `WSAGetLastError@0'
>> `WSAGetLastError@0'
> linked:
> = Martin Baranski
> = Eagle | Eagle3386
> pjsip mailing list
BP
Benny Prijono
Sun, Nov 11, 2007 12:09 AM
Doesn't anyone else feel that this thread is getting way way much
longer that it really should? I know everyone is keen to help, but
instructions have been clearly given in the website, we don't need
to repeat it here.
IMO this discussion has less to do to pjsip, but rather more to do
with applying pjsip build settings to your favorite IDE (which is
not supported by pjsip anyway), so it's probably best to take it to
the IDE's forum.
cheers,
-benny
to repeat it here.
the IDE's forum.
cheers,
-benny
RK
Roland Klabunde
Sun, Nov 11, 2007 12:35 AM
Benny, I already wanted to say three and a half postings before: Man, change
your signature. Cod(ing) MUST be PAIN for you...:)
Of course, I'm with you. Close this topic..
Regards
Sent: Sunday, November 11, 2007 1:09 AM
to repeat it here.
the IDE's forum.
cheers,
-benny
pjsip mailing list
Regards
> to repeat it here.
> the IDE's forum.
> cheers,
> -benny
> pjsip mailing list
EI
Sun, Nov 11, 2007 7:40 AM
Hi,
Platform SDK.
Thanks.
Hi Hitesh,
thanks for your hint - got it insert (although I additionally had to
insert the absolute path of the library into the linker's options,
too)..
So now, I only remain with 2 errors (instead of more than 50):
M:\pj-sip\pjlib\lib\libpjlib-i386-win32-vc8-debug.a(sock_bsd.o): In
function pj_sock_socket': M:/pj-sip/pjlib/src/pj/sock_bsd.c:347: undefined reference to WSASocketA@24'
M:\pj-sip\pjlib\lib\libpjlib-i386-win32-vc8-debug.a(guid_win32.o): In
function pj_generate_unique_string': M:/pj-sip/pjlib/src/pj/guid_win32.c:69: undefined reference to CoCreateGuid@4'
2 errors, 0 warnings
Benny,
I'm just thinking that the GCC should be supported, because that's
definitely a better compiler than MS' one.. I'm saying this, because I
had to work with VS 2003 .NET some time ago and especially the linker
was pure pain to me.. It threw errors where GCC worked just fine - and
GCC is stricter than MS' linker..
And since the compiler works fine and the IDE does what it's meant to
be, I don't see any reason for switching over to the
Code::Blocks-forums.
Instead, IMHO it's more a putting-pjsip-into-a-gcc-compatible-form-stuff.. ;)
Roland,
although this might be hard to understand, I want to say that this is
what makes me still saying "code is poetry" - all this hard work will
finally work and then, there's kind of silence and pleasure and what
I'm feeling in that moment is just awesome..
You know, that's this "still standing, fighting with the code and
finally win the battle"..
So, why close this topic as the final step is already in sight?
Martin..
2007/11/10, logan <logan04x@gmail.com>:
> Hi,
> Platform SDK.
> Thanks.
Hi Hitesh,
too)..
function `pj_sock_socket':
M:/pj-sip/pjlib/src/pj/sock_bsd.c:347: undefined reference to `WSASocketA@24'
function `pj_generate_unique_string':
M:/pj-sip/pjlib/src/pj/guid_win32.c:69: undefined reference to `CoCreateGuid@4'
Benny,
Roland,
Martin..
= Martin Baranski
= Eagle | Eagle3386
L
logan
Sun, Nov 11, 2007 8:29 AM
Hi,
Ahh, I'm sorry for my ignorance, the library for Winsock 2 is ws2_32.lib.
The first error should go with this. For the second one make sure you are
linking to ole32.lib (Hmm, I wonder why you didn't get errors for
CoCreateInstance and other COM API's before this, maybe the linker didn't
try further after getting this error?).
As of closing the thread, I guess road blocks like this happen with
everyone, so we can try to help a bit. But, as a side note you should try to
use the tools that are meant to be used with a particular library.
And, VC++ 2005 is a standard C++ compilant compiler. You should be able to
build all standard C++ projects with it. Maybe you were just getting some
weird errors that needed subtle changes in configuration of VC++ 2003.
Thanks.
Best Regards,
Hitesh
Sent: Sunday, November 11, 2007 1:10 PM
Hi,
Platform SDK.
Thanks.
Hi Hitesh,
too)..
Benny,
Roland,
Martin..
pjsip mailing list
Hi,
Thanks.
Best Regards,
Hitesh
>> Hi,
>> Platform SDK.
>> Thanks.
> Hi Hitesh,
> too)..
> `WSASocketA@24'
> `CoCreateGuid@4'
> Benny,
> Roland,
> Regards,
> Martin..
> = Martin Baranski
> = Eagle | Eagle3386
> pjsip mailing list
BP
Benny Prijono
Sun, Nov 11, 2007 10:38 AM
Eagle I Martin Baranski wrote:
Benny,
Thanks for the suggestion to support gcc, and I've added support for
gcc in pjsip... four years ago! You really really need to read the
Getting Started page to help you with building pjsip and avoid this
misconception.
Lets put this thread to rest already.
-benny
> Benny,
misconception.
-benny
RK
Roland Klabunde
Sun, Nov 11, 2007 12:21 PM
misconception.
Congratulation. I know Benny since years and I didn't manage to upset him
seriously. Martin, please consider to stop annoying the community with
precocious postings and stealing us time, nerves and mailbox space!
Regards
> misconception.
Regards
