GPS Antenna Grounding/Lightning protection.
DW
Dana Whitlow
Thu, Jun 21, 2018 1:28 AM
Assuming that the coax down lead is well bonded to the tower at the
antenna, couldn't some additional
protection be obtained by running the coax down the inside of the tower?
And shouldn't the coax from
the tower base to the grounding panel at the house be run in close
proximity to the big fat ground lead
that connects the tower base ground to the house panel?
Dana
On Wed, Jun 20, 2018 at 5:45 PM, Oz-in-DFW lists@ozindfw.net wrote:
The "Cone of Protection" is a thumbrule.  It's not a myth, but it's also
not an absolute law of nature. It's a self-fulfilling prophecy to some
degree because it drives component design guidelines.
Bunker spacing is also a thumbrule, based on a lot of horrible
experience. It's also a function of many variables and differing
requirements, largely the explosive involved.  It's also self-fulfilling
prophecy because it enters into design guidelines for explosives
packaging. There's a multitude of reasons those bricks are in a foil
bag. This is one of them.
I'm not a lightning protection expert, but I do a bit of work where I
have to be concerned about it. I look at that thumbrule, but I'm also a
belt and suspenders guy and apply many others. And I build shipping gear
as if it's going to South Africa (much worse that Florida.)
Back to my original statement early in this thread (rope?) "No matter
what you do, it's unlikely you can do anything within economical reason
to survive a direct strike and the 10's to 100's of kiloamps involved.
The real question is how close of a near miss can you survive." for a
small business/residential install, as a minimum I would:
  1. Make sure your tower is grounded.
  2. Make sure your tower is electrically sound (a good electrical
    conductor - all sections are well connected electrically. this is
    */NOT /*a given with used or old tower.) If you are going to clamp
    copper straps to the tower or antennas, use some stainless shim
    stock as a barrier.
  3. Mount your antenna(s) with grounding as specified by the manufacturer.
  4. Use a lightning/drip loop at the top of the tower as a absolute
    minimum.  Better to use a real suppressor, preferably of the 1/4
    wave stub type.
  5. Ground the coax shield to the tower at the top and the bottom.
  6. If you have control lines (power, rotator controls, etc.) use
    shielded cable, ground, and suppress as with coax.
  7. Use a master ground bar entry into your building, and make sure you
    have effective lightning suppression on /everything/ that enters
    the building: Coax, AC power, phone lines, ethernets, hopes, wishes,
    etc.
  8. Make sure the master ground bar is well grounded to the tower.  See
    https://www.solacity.com/docs/Polyphaser/Coaxial%20cable%
    20entry%20panels%20and%20coax%20grounding.PDF
    Commercial installs are copper bus bar.  I use it where I can, but I
    also have ham installs that use unistrut and copper strap.  In an
    ideal world this is next to the electrical service panel and ground
    there with suppressors on the AC lines into the building. The world
    is rarely ideal.
  9. I /try/ to bury at least 8 AWG ground wire around the building, but
    I'm usually lucky to get it between the AC panel,  coax entry, and
    tower.  One time I used scrap 1/2" copper water pipe.
  10. Get a good suppressor on the input feed to the AC panel. The /vast/
    majority of failures I've seen come in the AC line. Or phone line if
    you still have copper.
  11. Make sure your grounds really are.  A six foot 14 AWG wire is not a
    ground, even for a cable TV entry block. Use wide braid, strap, or
    welding cable size wire. And be careful how you route it.  There is
    a lot of literature on this alone. don't run it across the attic  ;-)
  12. If you want the buried stuff to last, look at some form of cathodic
    protection.
Of course you can do all of this and take losses from a hit, or none of
it and never see a problem.  This is, as the Polyphaser paper mentions,
insurance.
Oz
Shutting up now, sir.
On 6/19/2018 10:56 PM, Bill Hawkins wrote:
Seems to me that lightning protection for timenuts who put things on
masts keeps this from being completely off topic.
People who store explosives in earthen bunkers have learned from many
years of experience how far away bunkers have to be spaced so than an
explosion in one bunker won't affect others. That same body of
experience came up with the cone of protection.
It is not a myth.
Note that lightningsafety.com sells lightning protection. The scrolling
set of pictures on the home page shows a picture of four masts
protecting a rocket launch site.
Bill Hawkins
P.S. Lightning can enter a home in other ways. A neighbor had a direct
hit to a tree 15 feet from the house. After generating enough steam in a
2 foot diameter tree to split the length of it, a side strike hit an
outdoor light and did considerable damage in the house. The tree was not
the highest thing around. That same strike produced an EMP that took out
one of my two GPS antennas, about 100 feet away. The time from flash to
BANG was about 100 milliseconds. No, I didn't measure it - I experienced
it.
From: time-nuts [mailto:time-nuts-bounces@lists.febo.com] On Behalf Of
Van Horn, David
Sent: Tuesday, June 19, 2018 11:22 AM
About that "cone of protection"
http://lightningsafety.com/nlsi_pls/cone-of-protection-myth.html
mailto:oz@ozindfw.net
Oz
POB 93167
Southlake, TX 76092 (Near DFW Airport)
To unsubscribe, go to https://lists.febo.com/cgi-
bin/mailman/listinfo/time-nuts
Assuming that the coax down lead is well bonded to the tower at the antenna, couldn't some additional protection be obtained by running the coax down the inside of the tower? And shouldn't the coax from the tower base to the grounding panel at the house be run in close proximity to the big fat ground lead that connects the tower base ground to the house panel? Dana On Wed, Jun 20, 2018 at 5:45 PM, Oz-in-DFW <lists@ozindfw.net> wrote: > The "Cone of Protection" is a thumbrule. It's not a myth, but it's also > not an absolute law of nature. It's a self-fulfilling prophecy to some > degree because it drives component design guidelines. > > Bunker spacing is also a thumbrule, based on a lot of horrible > experience. It's also a function of many variables and differing > requirements, largely the explosive involved. It's also self-fulfilling > prophecy because it enters into design guidelines for explosives > packaging. There's a multitude of reasons those bricks are in a foil > bag. This is one of them. > > I'm not a lightning protection expert, but I do a bit of work where I > have to be concerned about it. I look at that thumbrule, but I'm also a > belt and suspenders guy and apply many others. And I build shipping gear > as if it's going to South Africa (much worse that Florida.) > > Back to my original statement early in this thread (rope?) "No matter > what you do, it's unlikely you can do anything within economical reason > to survive a direct strike and the 10's to 100's of kiloamps involved. > The real question is how close of a near miss can you survive." for a > small business/residential install, as a minimum I would: > > 1. Make sure your tower is grounded. > 2. Make sure your tower is electrically sound (a good electrical > conductor - all sections are well connected electrically. this is > */NOT /*a given with used or old tower.) If you are going to clamp > copper straps to the tower or antennas, use some stainless shim > stock as a barrier. > 3. Mount your antenna(s) with grounding as specified by the manufacturer. > 4. Use a lightning/drip loop at the top of the tower as a absolute > minimum. Better to use a real suppressor, preferably of the 1/4 > wave stub type. > 5. Ground the coax shield to the tower at the top and the bottom. > 6. If you have control lines (power, rotator controls, etc.) use > shielded cable, ground, and suppress as with coax. > 7. Use a master ground bar entry into your building, and make sure you > have effective lightning suppression on */everything/* that enters > the building: Coax, AC power, phone lines, ethernets, hopes, wishes, > etc. > 8. Make sure the master ground bar is well grounded to the tower. See > https://www.solacity.com/docs/Polyphaser/Coaxial%20cable% > 20entry%20panels%20and%20coax%20grounding.PDF > Commercial installs are copper bus bar. I use it where I can, but I > also have ham installs that use unistrut and copper strap. In an > ideal world this is next to the electrical service panel and ground > there with suppressors on the AC lines into the building. The world > is rarely ideal. > 9. I /try/ to bury at least 8 AWG ground wire around the building, but > I'm usually lucky to get it between the AC panel, coax entry, and > tower. One time I used scrap 1/2" copper water pipe. > 10. Get a good suppressor on the input feed to the AC panel. The /vast/ > majority of failures I've seen come in the AC line. Or phone line if > you still have copper. > 11. Make sure your grounds really are. A six foot 14 AWG wire is not a > ground, even for a cable TV entry block. Use wide braid, strap, or > welding cable size wire. And be careful how you route it. There is > a lot of literature on this alone. don't run it across the attic ;-) > 12. If you want the buried stuff to last, look at some form of cathodic > protection. > > Of course you can do all of this and take losses from a hit, or none of > it and never see a problem. This is, as the Polyphaser paper mentions, > insurance. > > Oz > > Shutting up now, sir. > > > On 6/19/2018 10:56 PM, Bill Hawkins wrote: > > Seems to me that lightning protection for timenuts who put things on > > masts keeps this from being completely off topic. > > > > People who store explosives in earthen bunkers have learned from many > > years of experience how far away bunkers have to be spaced so than an > > explosion in one bunker won't affect others. That same body of > > experience came up with the cone of protection. > > > > It is not a myth. > > > > Note that lightningsafety.com sells lightning protection. The scrolling > > set of pictures on the home page shows a picture of four masts > > protecting a rocket launch site. > > > > Bill Hawkins > > > > P.S. Lightning can enter a home in other ways. A neighbor had a direct > > hit to a tree 15 feet from the house. After generating enough steam in a > > 2 foot diameter tree to split the length of it, a side strike hit an > > outdoor light and did considerable damage in the house. The tree was not > > the highest thing around. That same strike produced an EMP that took out > > one of my two GPS antennas, about 100 feet away. The time from flash to > > BANG was about 100 milliseconds. No, I didn't measure it - I experienced > > it. > > > > > > -----Original Message----- > > From: time-nuts [mailto:time-nuts-bounces@lists.febo.com] On Behalf Of > > Van Horn, David > > Sent: Tuesday, June 19, 2018 11:22 AM > > > > About that "cone of protection" > > http://lightningsafety.com/nlsi_pls/cone-of-protection-myth.html > > > > > > > > -- > mailto:oz@ozindfw.net > Oz > POB 93167 > Southlake, TX 76092 (Near DFW Airport) > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to https://lists.febo.com/cgi- > bin/mailman/listinfo/time-nuts > and follow the instructions there. >
