MW
Matthias Welwarsky
Fri, Jan 1, 2021 12:39 AM
Happy New Year, Peter.
If you get the chance, would you also have a look at the buffered 1PPS signal?
I received my boards meanwhile and after mounting the LEA module I connected
the 1PPS output to a scope to measure the signal rise time. I'm getting around
6ns for the 10%-90% rise and the output is not quite reaching 2.5V. That is
not bad but not as fast as I'd like. I'm thinking of reducing R16/R17 to 68
Ohm to get the impedance closer to 50 Ohm.
Best regards,
Matthias
On Mittwoch, 30. Dezember 2020 17:56:37 CET Matthias Welwarsky wrote:
Quick heads-up for everyone who might have ordered the breakout board based
on design files I uploaded to github before Dec. 28th.
As Peter Bell found out, the voltage divider that provides VDD_USB to the
LEA module is not adequate, the impedance is way too high and since the
current drawn by the VDD_USB pin is quite variable, there is little chance
to dimension it correctly. However, it might still be possible to salvage
the boards. I suggested, and Peter verified it, that replacing R7 with a
red LED (0603 footprint), oriented such that the cathode connects to
VDD_USB, will provide an adequate supply to the pin and might even double
as an USB indicator light.
I've updated the files on github on Dec. 28th and added a 3.3V LDO regulator
instead of the resistor divider. This is the solution recommended in the
hardware integration manual for the LEA-M8.
My own boards still haven't arrived.
BR,
Matthias
On Samstag, 26. Dezember 2020 10:06:11 CET Peter Bell wrote:
Just a quick note for anyone building these - I got my boards back and
assembled them
and everything works except for the USB port. This is being caused by the
VDD_USB
pin being fairly low-impedance and dragging down the voltage of the R7/R9
potential
divider to about 700mV, at which point the module doesn't recognize it's
connected.
I guess the "proper" fix would be to add another 3.3V LDO to the board
that
runs from
VBUS and generates VDD_USB - but for testing purposes I removed R7 and
connected
the VDD_USB pin to the 3.3V on pin 2 of U4 - after doing this, the board
connected
and enumerated as a virtual COM port.
Pete
To unsubscribe, go to
http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com and follow
the instructions there.
Best regards,
Matthias
> BR,
> Matthias
> > assembled them
> > VDD_USB
> > potential
> > connected.
> > that
> > runs from
> > connected
> > connected
> > Regards,
> > Pete
> > _______________________________________________
BK
Bob kb8tq
Fri, Jan 1, 2021 12:55 AM
If you are looking at the “raw” output of the uBlox, it is not designed to drive
a low impedance. Even if there is a buffer, it may or may not like a low impedance
load.
On Dec 31, 2020, at 7:39 PM, Matthias Welwarsky time-nuts@welwarsky.de wrote:
Best regards,
Matthias
BR,
Matthias
assembled them
VDD_USB
potential
connected.
that
runs from
connected
connected
Pete
load.
> On Dec 31, 2020, at 7:39 PM, Matthias Welwarsky <time-nuts@welwarsky.de> wrote:
> Best regards,
> Matthias
>> BR,
>> Matthias
>>> assembled them
>>> VDD_USB
>>> potential
>>> connected.
>>> that
>>> runs from
>>> connected
>>> connected
>>> Regards,
>>> Pete
> To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
> and follow the instructions there.
