I have a simple program to import an STL file and then crop part of the shape away.
The preview function (F5) works as expected but when I render it (F6) CGAL throws
an error :-
ERROR: CGAL error in CGALUtils::applyBinaryOperator difference: CGAL ERROR: assertion violation! Expr: target(s1).vertex()==target(s2).vertex() File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_3/SNC_FM_decorator.h Line: 227
and the resulting display is as though the difference() wasn't applied.
The program is very simple (see below) and you can find the STL file HERE if you need it.
Am I missing or misunderstanding something ?? (wouldn't be the first time!)
Dave
include <BOSL/constants.scad>
use <BOSL/transforms.scad>
extra_width = 37;
module basis(){
// Move the imported object along "x" to the origin
// I got "143" from measuring distance from an edge to the YZ plane using "3DTool"
move([-143.00,0,0])
import("front.STL", convexity=5);
difference() {
basis();
translate([extra_width,-10,-20])
cube([200,100,200]);
The STL has self intersections. See the red line below.
[image: image.png]
OpenSCAD will only work with manifold STLs, i.e. no holes, self
intersections or degenerate triangles.
shape away.
throws
an error :-
File:
Line: 227
https://www.dropbox.com/s/3t0i6hmpr2811sl/front.STL?dl=0 if you need it.
Dave
extra_width = 37;
module basis(){
move([-143.00,0,0])
difference() {
basis();
Discuss@lists.openscad.org
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
I had it "fixed" using netfab's online service and now I get a different error.
ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: e->incident_sface() != SFace_const_handle() File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decorator.h Line: 329
Modified file available HERE
How did you get a copy of netfab basic ?? When I tried to download it it kept running around in a loop nd not starting the download.
Dave
That also has self intersections.
I downloaded NetFabb basic many years ago, when it was a free download. It
can detect self intersections but you need a paid version to fix them.
error.
Line: 329
https://www.dropbox.com/s/w8pnbbhufm59m0k/front_fixed.STL?dl=0
Dave
Well their online service leaves something to be desired :-(
I found another STL file that is OK so I'll continue with that :-)
Thanks for all the help,
Dave
I downloaded NetFabb basic many years ago, when it was a free download. It can detect self intersections but you need a paid version to fix them.
Dave_______________________________________________
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org<pre class="moz-quote-pre" wrap="">_______________________________________________ OpenSCAD mailing list <a class="moz-txt-link-abbreviated" href="mailto:Discuss@lists.openscad.org">Discuss@lists.openscad.org</a> <a class="moz-txt-link-freetext" href="http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org">http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org</a>
