View all threadsHi,
I’m having a problem using the front panel GPIO on an N320. I reverted back to a standard “HG” FPGA build and compiled the GPIO example program (UHD 3.14.0). However, when I run the example program I get the following:
Error: RuntimeError: The hardware has no gpio bank `FP0'
Is the front panel GPIO bank on the N320 called “FP0” or something else? I did not see a reference to this in the .dts.
See below for a “uhd_uspr_probe”, “uhd_config_info” dump, and the terminal output after running ./gpio.
Thanks for any help.
Ed Nowicki
xku@sdr_nuc:~/workarea-uhd/uhd/host/examples/gpio/build$ uhd_usrp_probe
[INFO] [UHD] linux; GNU C++ version 7.4.0; Boost_106501; UHD_3.14.0.HEAD-0-g6875d061
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.20.2,type=n3xx,product=n320,serial=31A5C5A,claimed=False,addr=192.168.20.2
[INFO] [MPM.PeriphManager] init() called with device args `mgmt_addr=192.168.20.2,clock_source=internal,time_source=internal,product=n320'.
[INFO] [MPM.Rhodium-0] init() called with args `mgmt_addr=192.168.20.2,clock_source=internal,time_source=internal,product=n320'
[INFO] [MPM.Rhodium-1] init() called with args `mgmt_addr=192.168.20.2,clock_source=internal,time_source=internal,product=n320'
[INFO] [0/Replay_0] Initializing block control (NOC ID: 0x4E91A00000000004)
[INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000000320)
[INFO] [0/Radio_1] Initializing block control (NOC ID: 0x12AD100000000320)
[INFO] [0/DDC_0] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_1] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DUC_0] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_1] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/FIFO_0] Initializing block control (NOC ID: 0xF1F0000000000000)
[INFO] [0/FIFO_1] Initializing block control (NOC ID: 0xF1F0000000000000)
_____________________________________________________
| Device: N300-Series Device
| | Mboard: ni-n3xx-31A5C5A
| | eeprom_version: 2
| | mpm_version: 3.14.1.0-gbfb9c1c7
| | pid: 16962
| | product: n320
| | rev: 7
| | rpc_connection: remote
| | serial: 31A5C5A
| | type: n3xx
| | MPM Version: 1.2
| | FPGA Version: 5.3
| | FPGA git hash: 3de8954.clean
| | RFNoC capable: Yes
| | Time sources: internal, external, gpsdo, sfp0
| | Clock sources: external, internal, gpsdo
| | Sensors: temp, gps_tpv, gps_time, fan, gps_sky, ref_locked, gps_gpgga, gps_locked
| | | RX Dboard: A
| | | Serial: 3191E7D
| | | | RX Frontend: 0
| | | | Antennas: TX/RX, RX2, CAL, TERM
| | | | Sensors: lo_locked
| | | | Freq range: 1.000 to 6000.000 MHz
| | | | Gain range all: 0.0 to 60.0 step 1.0 dB
| | | | Bandwidth range: 250000000.0 to 250000000.0 step 0.0 Hz
| | | | Connection Type:
| | | | Uses LO offset: No
| | | | RX Codec: A
| | | | Gain Elements: None
| | | RX Dboard: B
| | | Serial: 3191E79
| | | | RX Frontend: 0
| | | | Sensors: lo_locked
| | | | Connection Type:
| | | | Uses LO offset: No
| | | | RX Codec: B
| | | | Gain Elements: None
| | | TX Dboard: A
| | | Serial: 3191E7D
| | | | TX Frontend: 0
| | | | Antennas: TX/RX, CAL, TERM
| | | | Sensors: lo_locked
| | | | Connection Type:
| | | | Uses LO offset: No
| | | | TX Codec: A
| | | | Gain Elements: None
| | | TX Dboard: B
| | | Serial: 3191E79
| | | | TX Frontend: 0
| | | | Sensors: lo_locked
| | | | Connection Type:
| | | | Uses LO offset: No
| | | | TX Codec: B
| | | | Gain Elements: None
| | | RFNoC blocks on this device:
| | | * Replay_0
| | | * Radio_0
| | | * Radio_1
| | | * DDC_0
| | | * DDC_1
| | | * DUC_0
| | | * DUC_1
| | | * FIFO_0
| | | * FIFO_1
xku@sdr_nuc:~/workarea-uhd/uhd/host/examples/gpio/build$ uhd_config_info --print-all
UHD 3.14.0.HEAD-0-g6875d061
Build date: Thu, 20 Jun 2019 18:53:05
C compiler: GNU 7.4.0
C++ compiler: GNU 7.4.0
C flags: -DUHD_RFNOC_ENABLED -DHAVE_CONFIG_H -DUHD_LOG_MIN_LEVEL=1 -DUHD_LOG_CONSOLE_LEVEL=2 -DUHD_LOG_FILE_LEVEL=2 -DUHD_LOG_CONSOLE_COLOR
C++ flags: -DUHD_RFNOC_ENABLED -DHAVE_CONFIG_H -DUHD_LOG_MIN_LEVEL=1 -DUHD_LOG_CONSOLE_LEVEL=2 -DUHD_LOG_FILE_LEVEL=2 -DUHD_LOG_CONSOLE_COLOR -fvisibility=hidden -fvisibility-inlines-hidden
Enabled components: LibUHD, LibUHD - C API, LibUHD - Python API, Examples, Utils, Tests, USB, B100, B200, USRP1, USRP2, X300, N230, MPMD, N300, N320, E320, OctoClock
Install prefix: /usr/local
Boost version: 1.65.1
Libusb version: 1.0.23
Package path: /usr/local
Images directory: /usr/local/share/uhd/images
ABI version string: 3.14.0
xku@sdr_nuc:~/workarea-uhd/uhd/host/examples/gpio/build$ ./gpio
Creating the usrp device with: ...
[INFO] [MPM.PeriphManager] init() called with device args mgmt_addr=192.168.20.2,clock_source=internal,time_source=internal,product=n320'. [INFO] [MPM.Rhodium-0] init() called with args
Using Device: Single USRP:
Mboard 0: ni-n3xx-31A5C5A
RX Channel: 0
RX DSP: 0
RX Dboard: A
RX Subdev: Rhodium
RX Channel: 1
RX DSP: 0
RX Dboard: B
RX Subdev: Rhodium
TX Channel: 0
TX DSP: 0
TX Dboard: A
TX Subdev: Rhodium
TX Channel: 1
TX DSP: 0
TX Dboard: B
TX Subdev: Rhodium
Initial GPIO values:
Bit 10 9 8 7 6 5 4 3 2 1 0
