Lucent RFTG-m-XO
T
TheInfamousFlavio@hotmail.com
Wed, Feb 7, 2007 3:59 AM
I had the exact same problem as yours.  I discoverd that my 106B had a
6-channel board in it vs. the 8-channel that is supposed to be in there.
I put a 8-channel board in and the fault and GPS lights went out.
To: "'Discussion of precise time and frequency measurement'"
Sent: Tuesday, February 06, 2007 11:27
Subject: Re: [time-nuts] Lucent RFTG-m-XO
Over the weekend I left the XO unit running for 38 hours, with it
installed
in its "house"  (No probing).  The GPS receiver was tracking satellites at
the start and also at the end of the run as verified by monitoring J5-2
w/VisualGPS.  The Fault & No GPS LEDs never went out.  I'm about to
conclude
that I have a defective unit and will order another unless anyone has any
further suggestions (PLEASE)?
I see at least John A., Jim M., & Phil S. have working XO units.  I have
just reviewed all the emails on the RFTG units and believe I have tried
all
the previous suggestions.  Any additional secrets to share???
Bob Martinson, N1VQR
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On
Behalf Of Phil Staton
Sent: Thursday, February 01, 2007 6:53 PM
To: time-nuts@febo.com
Subject: [time-nuts] Lucent RFTG-m-XO
Briefly:
Leave it running for at least 24hrs.
The 15MHz will slowly get on freq.
Countup is available on 1pps socket.
more when I have time
time-nuts mailing list
I had the exact same problem as yours. I discoverd that my 106B had a 6-channel board in it vs. the 8-channel that is supposed to be in there. I put a 8-channel board in and the fault and GPS lights went out. ----- Original Message ----- From: "Robert E. Martinson" <REMartinson@rcn.com> To: "'Discussion of precise time and frequency measurement'" <time-nuts@febo.com> Sent: Tuesday, February 06, 2007 11:27 Subject: Re: [time-nuts] Lucent RFTG-m-XO > Over the weekend I left the XO unit running for 38 hours, with it > installed > in its "house" (No probing). The GPS receiver was tracking satellites at > the start and also at the end of the run as verified by monitoring J5-2 > w/VisualGPS. The Fault & No GPS LEDs never went out. I'm about to > conclude > that I have a defective unit and will order another unless anyone has any > further suggestions (PLEASE)? > > > I see at least John A., Jim M., & Phil S. have working XO units. I have > just reviewed all the emails on the RFTG units and believe I have tried > all > the previous suggestions. Any additional secrets to share??? > > > Bob Martinson, N1VQR > > > > -----Original Message----- > From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On > Behalf Of Phil Staton > Sent: Thursday, February 01, 2007 6:53 PM > To: time-nuts@febo.com > Subject: [time-nuts] Lucent RFTG-m-XO > > > Briefly: > Leave it running for at least 24hrs. > The 15MHz will slowly get on freq. > Countup is available on 1pps socket. > more when I have time > > _______________________________________________ > time-nuts mailing list > time-nuts@febo.com > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > _______________________________________________ > time-nuts mailing list > time-nuts@febo.com > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >
SB
Steve1 Baillargeon
Wed, Feb 7, 2007 4:47 PM
Is this link correct? I don't see refrences to antenna cables?
From: Dr Bruce Griffiths bruce.griffiths@xtra.co.nz
Reply-To: Discussion of precise time and frequency
measurementtime-nuts@febo.com
To: Discussion of precise time and frequency measurement
Subject: [time-nuts] Importance of matching antenna cable for GPS
timingreceiver
Date: Wed, 07 Feb 2007 11:13:29 +1300
Those who maintain that its OK to use 75 ohm GPS antenna cable should read:
http://tf.nist.gov/timefreq/general/pdf/1380.pdf
Is this link correct? I don't see refrences to antenna cables? >From: Dr Bruce Griffiths <bruce.griffiths@xtra.co.nz> >Reply-To: Discussion of precise time and frequency >measurement<time-nuts@febo.com> >To: Discussion of precise time and frequency measurement ><time-nuts@febo.com> >Subject: [time-nuts] Importance of matching antenna cable for GPS >timingreceiver >Date: Wed, 07 Feb 2007 11:13:29 +1300 > >Those who maintain that its OK to use 75 ohm GPS antenna cable should read: > >http://tf.nist.gov/timefreq/general/pdf/1380.pdf > >Bruce > >_______________________________________________ >time-nuts mailing list >time-nuts@febo.com >https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts _________________________________________________________________ Invite your Hotmail contacts to join your friends list with Windows Live Spaces http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
RK
Rob Kimberley
Wed, Feb 7, 2007 7:55 PM
Hi Steve,
Correct link was posted later by Bruce Griffiths
Hope all OK with you and yours.
Rob Kimberley
Behalf Of Steve1 Baillargeon
Sent: 07 February 2007 16:48
Subject: Re: [time-nuts] Importance of matching antenna cable for
GPStimingreceiver
timingreceiver
Spaces
Hi Steve, Correct link was posted later by Bruce Griffiths >> http://tf.nist.gov/timefreq/general/pdf/1384.pdf Hope all OK with you and yours. Rob Kimberley -----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Steve1 Baillargeon Sent: 07 February 2007 16:48 To: time-nuts@febo.com Subject: Re: [time-nuts] Importance of matching antenna cable for GPStimingreceiver Is this link correct? I don't see refrences to antenna cables? >From: Dr Bruce Griffiths <bruce.griffiths@xtra.co.nz> >Reply-To: Discussion of precise time and frequency >measurement<time-nuts@febo.com> >To: Discussion of precise time and frequency measurement ><time-nuts@febo.com> >Subject: [time-nuts] Importance of matching antenna cable for GPS >timingreceiver >Date: Wed, 07 Feb 2007 11:13:29 +1300 > >Those who maintain that its OK to use 75 ohm GPS antenna cable should read: > >http://tf.nist.gov/timefreq/general/pdf/1380.pdf > >Bruce > >_______________________________________________ >time-nuts mailing list >time-nuts@febo.com >https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts _________________________________________________________________ Invite your Hotmail contacts to join your friends list with Windows Live Spaces http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spa ces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us _______________________________________________ time-nuts mailing list time-nuts@febo.com https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
DB
Dr Bruce Griffiths
Wed, Feb 7, 2007 9:03 PM
No a slight typo should have been
Steve1 Baillargeon wrote: > Is this link correct? I don't see refrences to antenna cables? > > No a slight typo should have been http://tf.nist.gov/timefreq/general/pdf/1384.pdf Bruce
SB
Steve1 Baillargeon
Wed, Feb 7, 2007 10:28 PM
Thanks,
Very interesting artical, it will take some time to digest.....
forGPS timingreceiver
Date: Thu, 08 Feb 2007 10:03:36 +1300
Thanks, Very interesting artical, it will take some time to digest..... >From: Dr Bruce Griffiths <bruce.griffiths@xtra.co.nz> >Reply-To: Discussion of precise time and frequency >measurement<time-nuts@febo.com> >To: Discussion of precise time and frequency measurement ><time-nuts@febo.com> >Subject: Re: [time-nuts] Importance of matching antenna cable >forGPS timingreceiver >Date: Thu, 08 Feb 2007 10:03:36 +1300 > >Steve1 Baillargeon wrote: > > Is this link correct? I don't see refrences to antenna cables? > > > > >No a slight typo should have been > >http://tf.nist.gov/timefreq/general/pdf/1384.pdf > > >Bruce > >_______________________________________________ >time-nuts mailing list >time-nuts@febo.com >https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts _________________________________________________________________ Turn searches into helpful donations. Make your search count. http://click4thecause.live.com/search/charity/default.aspx?source=hmemtagline_donation&FORM=WLMTAG
