I have recently removed a lot of fittings from the balsa cored deck of one
of my boats. I am presently coating the deck with kiwigrip. In a couple
of days I will have to reinstall the deck fittings using the technique of
removing core in the fastening area and redrilling. I may use butyl rubber
around the beveled top of the screw holes. My question is:
What have listees found to be the best sealant for fasteners in a cored
deck?
Richard P.
Richard,
The way I was taught years ago is that the best way to insure that you don't
get leaks at screw holes is to drill out the screw holes to oversize, then
fill them with fiberglass resin or another suitable permanent resin. Let
the resin cure and then drill a new hole in the resin being careful not to
go past the resin either in diameter or depth and then screw your attachment
screws into the resin. In this manner the screw is surrounded by resin and
does not come into contact with the core material, such as balsa, thus even
if water penetrates along the screw threads it never gets to the core
material and thus does not cause future rot or damage.
Just my two cents worth.
Good luck,
George
MV-Valhalla
"And the sea will grant each man new hope, as sleep brings dreams of home."
From: Trawlers-and-Trawlering [mailto:trawlers-bounces@lists.trawlering.com]
On Behalf Of Richard P via Trawlers-and-Trawlering
Sent: Tuesday, February 2, 2021 9:48 PM
To: trawlers@lists.trawlering.com trawlers@lists.trawlering.com
Subject: T&T: best sealant for deck fastenings
deck?
Richard P.
http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
To unsubscribe or modify your subscription options (get password, change
email address, etc) go to:
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
George's idea to 'pot' the fasteners is one that should be followed on any
cored deck. If your fasteners go all the way through-"through bolted'-
that's okay, too, as any leaking, as long as the resin hadn't been
compromised when re-drilled, will force the water to exit out the bottom,
thus providing a red flag that indicates that the fitting needs to be
rebedded.
The second advantage of potting fasteners in a cored deck is that the resin
also fulfills the function of a compression post.
*Rudy & Jill Sechez *
*BRINEY BUG-a 34' Sail-Assisted Trawler *
850-832-7748
www.trawlertrainingabc.com http://www.trawlertrainingabc.com
Cocoa FL
On Wed, Feb 3, 2021 at 3:07 AM DieselTrawlerGuy via Trawlers-and-Trawlering
trawlers@lists.trawlering.com wrote:
Richard,
don't
Good luck,
George
MV-Valhalla
deck?
Richard P.
In the current issue of Professional Boatbuilder (mine came two days
ago) there is an entire article dedicated to fastening to a deck. The
author basically uses the method George suggests, but with the addition
of gouging out a bit of core material between the deck and the bottom
layers of fiberglass (if that's the type of construction you're dealing
with) around the edges of the hole before adding the resin and letting
it cure. That helps to prevent any water intrusion as well as
strengthens the deck structure immediately adjacent to the hole you'll
eventually drill. There are various methods of gouging out the core
material; the author suggested a Dremel tool, or chucking a hex wrench
into a drill.
<><><><><><><><><><><><>Mozilla Thunderbird<><><><><><><><><><>
Bob McLeran and Judy Young
Manatee Cove Marina, Patrick AFB Florida
Formerly cruising in MV Sanderling, a DeFever 41 Trawler
which has been sold
Blog: http://mvsanderling.net/Blog
On 2/3/2021 03:06 AM, DieselTrawlerGuy via Trawlers-and-Trawlering wrote:
Richard,
