Odd request
MA
Mark Amos
Thu, Jan 25, 2007 9:50 PM
Time-nuts
I appreciate the comments regarding horological obsession.  Mine started with a desire for an accurate master
oscillator for my ham shack (built and use a couple Shera GPSDO's) and has blossomed into a much broader interest
in time (Ex tempus, sapientia?)
This has led me to a silly quest.  I'd like to use a traditional clock face and hands as an output device for a
1PPS signal from my GPSDO.
I know this is a very broad question, but does anyone have advice on where I might start hacking (or making) a
mechanical clock face to accomplish this? Is there a simple clock design that I could start with to build my own?
Maybe replacing a pendulum or escapement with a solenoid?  Any examples to work from?
Mark
Time-nuts I appreciate the comments regarding horological obsession. Mine started with a desire for an accurate master oscillator for my ham shack (built and use a couple Shera GPSDO's) and has blossomed into a much broader interest in time (Ex tempus, sapientia?) This has led me to a silly quest. I'd like to use a traditional clock face and hands as an output device for a 1PPS signal from my GPSDO. I know this is a very broad question, but does anyone have advice on where I might start hacking (or making) a mechanical clock face to accomplish this? Is there a simple clock design that I could start with to build my own? Maybe replacing a pendulum or escapement with a solenoid? Any examples to work from? Mark
J
jmfranke
Thu, Jan 25, 2007 9:57 PM
I am going the same route and have discovered slave clocks which are
solenoid driven clocks.  The clocks were once very popular in schools and
factories. The hands typically step in one minute steps.
See: http://www.clockhistory.com/setclocks/index.html
I plan to use one of the clock movements to display minutes and hours and a
two digit LED digital display for the seconds.  I will divide the 1PPS
output from a Z3801A by 60 to get 1PPM.
John  WA4WDL
To: time-nuts@febo.com
Sent: Thursday, January 25, 2007 4:50 PM
Subject: [time-nuts] Odd request
Time-nuts
work from?
Mark
time-nuts mailing list
I am going the same route and have discovered slave clocks which are solenoid driven clocks. The clocks were once very popular in schools and factories. The hands typically step in one minute steps. See: http://www.clockhistory.com/setclocks/index.html I plan to use one of the clock movements to display minutes and hours and a two digit LED digital display for the seconds. I will divide the 1PPS output from a Z3801A by 60 to get 1PPM. John WA4WDL ----- Original Message ----- From: "Mark Amos" <mark.amos@toast.net> To: <time-nuts@febo.com> Sent: Thursday, January 25, 2007 4:50 PM Subject: [time-nuts] Odd request > Time-nuts > > I appreciate the comments regarding horological obsession. Mine started > with a desire for an accurate master > oscillator for my ham shack (built and use a couple Shera GPSDO's) and has > blossomed into a much broader interest > in time (Ex tempus, sapientia?) > > This has led me to a silly quest. I'd like to use a traditional clock > face and hands as an output device for a > 1PPS signal from my GPSDO. > > I know this is a very broad question, but does anyone have advice on where > I might start hacking (or making) a > mechanical clock face to accomplish this? Is there a simple clock design > that I could start with to build my own? > Maybe replacing a pendulum or escapement with a solenoid? Any examples to > work from? > > Mark > > > > > _______________________________________________ > time-nuts mailing list > time-nuts@febo.com > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >
TV
Tom Van Baak (mobile)
Thu, Jan 25, 2007 10:12 PM
Time-nuts
Mark
This is one reason the older model HP 5065A and 5061A
with Patek analog clocks are so desirable; they pre-date
LED, LCD, or VFD clock displays.
But one easy way to do it today is start with a $5 standard
quartz clock display. 1) Either run a precise synthesized
32 kHz signal into it (replacing the xtal), or drive the little
bipolar stepper yourself.
A 50 millisecond +1.5 VDC pulse is all you need; next
second give it a -1.5 VDC pulse, etc. This is a few lines
of code for a microcontroller. I've got pictures of this
somewhere on my web site, I think.
See also Bryan's cool stuff at:
http://www.bmumford.com/clocks/emindex.html
Some of us have driven traditional pendulum clocks with
GPS or atomic 1PPS. Another cute one is to take an
old Western Union, US Naval Observatory, SWCC
(Self-winding Clock Company) clocks and sync them
using a GPS-divided 1PPH (one pulse per hour) pulse.
See Mitchell's SWCC page at:
http://www.telechron.com/
Also, here's what "USNO time" meant in the 1930's...
http://www.leapsecond.com/history/usno.htm
/tvb
> Time-nuts > > I appreciate the comments regarding horological obsession. Mine started with a desire for an accurate master > oscillator for my ham shack (built and use a couple Shera GPSDO's) and has blossomed into a much broader interest > in time (Ex tempus, sapientia?) > > This has led me to a silly quest. I'd like to use a traditional clock face and hands as an output device for a > 1PPS signal from my GPSDO. > > I know this is a very broad question, but does anyone have advice on where I might start hacking (or making) a > mechanical clock face to accomplish this? Is there a simple clock design that I could start with to build my own? > Maybe replacing a pendulum or escapement with a solenoid? Any examples to work from? > > Mark This is one reason the older model HP 5065A and 5061A with Patek analog clocks are so desirable; they pre-date LED, LCD, or VFD clock displays. But one easy way to do it today is start with a $5 standard quartz clock display. 1) Either run a precise synthesized 32 kHz signal into it (replacing the xtal), or drive the little bipolar stepper yourself. A 50 millisecond +1.5 VDC pulse is all you need; next second give it a -1.5 VDC pulse, etc. This is a few lines of code for a microcontroller. I've got pictures of this somewhere on my web site, I think. See also Bryan's cool stuff at: http://www.bmumford.com/clocks/emindex.html Some of us have driven traditional pendulum clocks with GPS or atomic 1PPS. Another cute one is to take an old Western Union, US Naval Observatory, SWCC (Self-winding Clock Company) clocks and sync them using a GPS-divided 1PPH (one pulse per hour) pulse. See Mitchell's SWCC page at: http://www.telechron.com/ Also, here's what "USNO time" meant in the 1930's... http://www.leapsecond.com/history/usno.htm /tvb
BC
Brooke Clarke
Thu, Jan 25, 2007 10:22 PM
Hi Mark:
There may be some other approaches.
Start from an electric clock that's battery powered and replace all the
driving electronics and just drive the coil directly with  the proper
pulse rate.
Start from an electric clock and replace just the crystal with a 32768
kHz signal.
In the above cases I think you can find clocks with second hands.
I've been thinking that it should be possible us use synchro motors (3
phase drive) to allow smooth movement of the hands and also to have
continuous 360 degree rotation unlike model RC servo motors that don't
have 360 degree rotation.
I'm still working on packaging my Precision Clock, see:
http://www.pacificsites.com/~brooke/PRC68COM.shtml#PC3
Have Fun,
Brooke Clarke
w/Java http://www.PRC68.com
w/o Java http://www.pacificsites.com/~brooke/PRC68COM.shtml
http://www.precisionclock.com
Mark Amos wrote:
Time-nuts
Mark
Hi Mark: There may be some other approaches. Start from an electric clock that's battery powered and replace all the driving electronics and just drive the coil directly with the proper pulse rate. Start from an electric clock and replace just the crystal with a 32768 kHz signal. In the above cases I think you can find clocks with second hands. I've been thinking that it should be possible us use synchro motors (3 phase drive) to allow smooth movement of the hands and also to have continuous 360 degree rotation unlike model RC servo motors that don't have 360 degree rotation. I'm still working on packaging my Precision Clock, see: http://www.pacificsites.com/~brooke/PRC68COM.shtml#PC3 Have Fun, Brooke Clarke w/Java http://www.PRC68.com w/o Java http://www.pacificsites.com/~brooke/PRC68COM.shtml http://www.precisionclock.com Mark Amos wrote: >Time-nuts > >I appreciate the comments regarding horological obsession. Mine started with a desire for an accurate master >oscillator for my ham shack (built and use a couple Shera GPSDO's) and has blossomed into a much broader interest >in time (Ex tempus, sapientia?) > >This has led me to a silly quest. I'd like to use a traditional clock face and hands as an output device for a >1PPS signal from my GPSDO. > >I know this is a very broad question, but does anyone have advice on where I might start hacking (or making) a >mechanical clock face to accomplish this? Is there a simple clock design that I could start with to build my own? >Maybe replacing a pendulum or escapement with a solenoid? Any examples to work from? > >Mark > > >
DF
David Forbes
Thu, Jan 25, 2007 10:26 PM
Tom,
With all due respect to your love of software, a microcontroller is a
bit of overkill for this application.
Use a 74HC74 D flip-flop connected as a divide-by-two toggle register:
connect Q-not to the D input and feed the 1PPS into the C input; connect
S and R to +5V.
The drive pulse to the coil is generated very simply with a capacitor
(~0.1 uf?) in series with the clock solenoid. This will produce a
positive pulse when the flip-flop flips and a negative pulse when it flops.
You don't need to worry about the 1.5V coil voltage rating - the
capacitor will absorb the blow. I'd start out with a smaller capacitor
(.001uf maybe) and increase it until it pulses reliably, then select
perhaps twice that capacitance for reliability.
Tom Van Baak (mobile) wrote: > > But one easy way to do it today is start with a $5 standard > quartz clock display. 1) Either run a precise synthesized > 32 kHz signal into it (replacing the xtal), or drive the little > bipolar stepper yourself. > > A 50 millisecond +1.5 VDC pulse is all you need; next > second give it a -1.5 VDC pulse, etc. This is a few lines > of code for a microcontroller. I've got pictures of this > somewhere on my web site, I think. > Tom, With all due respect to your love of software, a microcontroller is a bit of overkill for this application. Use a 74HC74 D flip-flop connected as a divide-by-two toggle register: connect Q-not to the D input and feed the 1PPS into the C input; connect S and R to +5V. The drive pulse to the coil is generated very simply with a capacitor (~0.1 uf?) in series with the clock solenoid. This will produce a positive pulse when the flip-flop flips and a negative pulse when it flops. You don't need to worry about the 1.5V coil voltage rating - the capacitor will absorb the blow. I'd start out with a smaller capacitor (.001uf maybe) and increase it until it pulses reliably, then select perhaps twice that capacitance for reliability.
S
shoppa@trailing-edge.com
Thu, Jan 25, 2007 10:30 PM
Mine is obviously inherited. Mixed in among all the pictures of me
as a baby are pictures of hundreds of pocketwatches (mostly railroad
watches) that my dad collected :-).
Quartz clock movements with a second hand do exactly what you want. Deliver
1PPS and the second hand goes forward a tick a second.
Multiply up to 60Hz and drive a traditional 60Hz AC clock (TVB or
someone else illustrates
this with test equipment supplies driven from atomic clocks,
but this is, let's just say, overkill, but what isn't? :-) )
There are Bulova and other brands of instrumentation clocks that
are driven at more than 1PPS for smoother second hand movement.
Some of this shows up in the surplus stream. Most used Tuning forks
for the original frequency standard.
There are various synchronized clock movements out there that
show up on the surplus market but they usually have once-per-hour
and once-per-day sync pulses, not once-per-second.
Tim.
"Mark Amos" <mark.amos@toast.net> wrote: > I appreciate the comments regarding horological obsession. Mine started with a desire for an accurate master > oscillator for my ham shack (built and use a couple Shera GPSDO's) and has blossomed into a much broader interest > in time (Ex tempus, sapientia?) Mine is obviously inherited. Mixed in among all the pictures of me as a baby are pictures of hundreds of pocketwatches (mostly railroad watches) that my dad collected :-). > This has led me to a silly quest. I'd like to use a traditional clock face and hands as an output device for a > 1PPS signal from my GPSDO. Quartz clock movements with a second hand do exactly what you want. Deliver 1PPS and the second hand goes forward a tick a second. Multiply up to 60Hz and drive a traditional 60Hz AC clock (TVB or someone else illustrates this with test equipment supplies driven from atomic clocks, but this is, let's just say, overkill, but what isn't? :-) ) There are Bulova and other brands of instrumentation clocks that are driven at more than 1PPS for smoother second hand movement. Some of this shows up in the surplus stream. Most used Tuning forks for the original frequency standard. There are various synchronized clock movements out there that show up on the surplus market but they usually have once-per-hour and once-per-day sync pulses, not once-per-second. Tim.
JH
Jack Hudler
Thu, Jan 25, 2007 10:35 PM
There are some clocks like the ones in schools that use a 1PPS, 1PPM or faster.
On eBay
230081995247 nice
110082857347 neat!!
250076726064
110081232209
180076563718
This guy is selling a master simulator 200071362893
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf
Of Mark Amos
Sent: Thursday, January 25, 2007 3:51 PM
Time-nuts
from?
Mark
There are some clocks like the ones in schools that use a 1PPS, 1PPM or faster. On eBay 230081995247 nice 110082857347 neat!! 250076726064 110081232209 180076563718 This guy is selling a master simulator 200071362893 -----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Mark Amos Sent: Thursday, January 25, 2007 3:51 PM To: time-nuts@febo.com Subject: [time-nuts] Odd request Time-nuts I appreciate the comments regarding horological obsession. Mine started with a desire for an accurate master oscillator for my ham shack (built and use a couple Shera GPSDO's) and has blossomed into a much broader interest in time (Ex tempus, sapientia?) This has led me to a silly quest. I'd like to use a traditional clock face and hands as an output device for a 1PPS signal from my GPSDO. I know this is a very broad question, but does anyone have advice on where I might start hacking (or making) a mechanical clock face to accomplish this? Is there a simple clock design that I could start with to build my own? Maybe replacing a pendulum or escapement with a solenoid? Any examples to work from? Mark _______________________________________________ time-nuts mailing list time-nuts@febo.com https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
BJ
Bill Janssen
Thu, Jan 25, 2007 11:07 PM
Mark Amos wrote:
Time-nuts
Mark
Battery powered clocks are available in hobby shops especially those
that cater to woodworkers. They have a wide selection
of hands for every application. You would have to hack the electric part
but I think that is do-able.
Bill K7NOM
Mark Amos wrote: > Time-nuts > > I appreciate the comments regarding horological obsession. Mine started with a desire for an accurate master > oscillator for my ham shack (built and use a couple Shera GPSDO's) and has blossomed into a much broader interest > in time (Ex tempus, sapientia?) > > This has led me to a silly quest. I'd like to use a traditional clock face and hands as an output device for a > 1PPS signal from my GPSDO. > > I know this is a very broad question, but does anyone have advice on where I might start hacking (or making) a > mechanical clock face to accomplish this? Is there a simple clock design that I could start with to build my own? > Maybe replacing a pendulum or escapement with a solenoid? Any examples to work from? > > Mark > Battery powered clocks are available in hobby shops especially those that cater to woodworkers. They have a wide selection of hands for every application. You would have to hack the electric part but I think that is do-able. Bill K7NOM
DB
Dave Brown
To: "Discussion of precise time and frequency measurement"
Sent: Friday, January 26, 2007 10:57 AM
Subject: Re: [time-nuts] Odd request
schools and
hours and a
1PPS
John  WA4WDL
Some used a 30 second pulse as well - might pay to check the
particular slave you have before you make the divider!    I have a
Gents master clock here- I DID want to put it in the lounge but it was
considerd too 'industrial' so its been relegated to 'outer darkness'!
Personally I think it's rather elegant, but......
Picture here-
http://homepages.ihug.co.nz/~tractorb/gents%20master.gif
These were made in two pendulum lengths-this is the longer case (3
foot pendulum) model.
DaveB, NZ
----- Original Message ----- From: "jmfranke" <jmfranke@cox.net> To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> Sent: Friday, January 26, 2007 10:57 AM Subject: Re: [time-nuts] Odd request >I am going the same route and have discovered slave clocks which are > solenoid driven clocks. The clocks were once very popular in > schools and > factories. The hands typically step in one minute steps. > > See: http://www.clockhistory.com/setclocks/index.html > > I plan to use one of the clock movements to display minutes and > hours and a > two digit LED digital display for the seconds. I will divide the > 1PPS > output from a Z3801A by 60 to get 1PPM. > > John WA4WDL Some used a 30 second pulse as well - might pay to check the particular slave you have before you make the divider! I have a Gents master clock here- I DID want to put it in the lounge but it was considerd too 'industrial' so its been relegated to 'outer darkness'! Personally I think it's rather elegant, but...... Picture here- http://homepages.ihug.co.nz/~tractorb/gents%20master.gif These were made in two pendulum lengths-this is the longer case (3 foot pendulum) model. DaveB, NZ
JH
Jack Hudler
Thu, Jan 25, 2007 11:09 PM
It is elegant! Was that the XYL's opinion?
Of Dave Brown
Sent: Thursday, January 25, 2007 5:07 PM
To: Discussion of precise time and frequency measurement
schools and
hours and a
1PPS
John  WA4WDL
Picture here-
DaveB, NZ
It is elegant! Was that the XYL's opinion? -----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Dave Brown Sent: Thursday, January 25, 2007 5:07 PM To: Discussion of precise time and frequency measurement Subject: Re: [time-nuts] Odd request ----- Original Message ----- From: "jmfranke" <jmfranke@cox.net> To: "Discussion of precise time and frequency measurement" <time-nuts@febo.com> Sent: Friday, January 26, 2007 10:57 AM Subject: Re: [time-nuts] Odd request >I am going the same route and have discovered slave clocks which are > solenoid driven clocks. The clocks were once very popular in > schools and > factories. The hands typically step in one minute steps. > > See: http://www.clockhistory.com/setclocks/index.html > > I plan to use one of the clock movements to display minutes and > hours and a > two digit LED digital display for the seconds. I will divide the > 1PPS > output from a Z3801A by 60 to get 1PPM. > > John WA4WDL Some used a 30 second pulse as well - might pay to check the particular slave you have before you make the divider! I have a Gents master clock here- I DID want to put it in the lounge but it was considerd too 'industrial' so its been relegated to 'outer darkness'! Personally I think it's rather elegant, but...... Picture here- http://homepages.ihug.co.nz/~tractorb/gents%20master.gif These were made in two pendulum lengths-this is the longer case (3 foot pendulum) model. DaveB, NZ _______________________________________________ time-nuts mailing list time-nuts@febo.com https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
