trawler-buy-sell-trade@lists.trawlering.com
BUY, SELL AND TRADE TRAWLERS AND TRAWLERING GEAR
Hookah 2 diver system for sale
JM
Joe MANELIS
Tue, Jul 2, 2019 2:03 PM
Perfect system for 1 or 2 divers either for recreational diving or underwater boat maintenance.
Offered for sale in the Great Lakes area. Will deliver to any boat in the Great Lakes doing the loop.
Gator Gill Elite Series Two Diver Combo Packages with Reel
1- 2 Gallon Aluminum Tank Compressor with mini extension / alloy quick connect and        heat shield with washable internal filter
1- Universal Gator Reel & adapter for dive line (steel reel coated with PUR
( adapter plate and rode powder coated aluminum )
2-20 ft extensions with 2 way Y / Stainless Steel pressed stamped air breathing line
( connects from compressor mini extension to 10 ft reel ext. )
1- 10 ft extensions with alloy quick connect and male alloy plug
( connects from side of reel to 20ft extension that connects to pump )
1- 15' extension with alloy quick connect and male alloy plug
2-Dive lines with Stainless Steel pressed and alloy quick connects
(stamped breathing air)
2- Cressi Lo-Pro Regulators with adj. air flow and reusable in-line 40 micron filter
2- Carabiner clips and Gator safety clips for underwater quick connect
This reel fits a standard rod holder. Single down hose has a ‘Y’ at the bottom where up to 2 divers can be connected with 20’ hoses each. Goes down to 75’ deep.
I’ve only used this less than 6 times. It’s quite literally like new.
Asking $1,250. FIRM.
Included is a hvy. duty deep cycle battery that will put and keep 2 divers down for up to 3 hours!!!
I just don’t use it as much as expected.
I can be contacted by phone at 989-714-2553. Best email address is jjmanel@aol.com
Joe MANELIS
Perfect system for 1 or 2 divers either for recreational diving or underwater boat maintenance. Offered for sale in the Great Lakes area. Will deliver to any boat in the Great Lakes doing the loop. Gator Gill Elite Series Two Diver Combo Packages with Reel 1- 2 Gallon Aluminum Tank Compressor with mini extension / alloy quick connect and heat shield with washable internal filter 1- Universal Gator Reel & adapter for dive line (steel reel coated with PUR ( adapter plate and rode powder coated aluminum ) 2-20 ft extensions with 2 way Y / Stainless Steel pressed stamped air breathing line ( connects from compressor mini extension to 10 ft reel ext. ) 1- 10 ft extensions with alloy quick connect and male alloy plug ( connects from side of reel to 20ft extension that connects to pump ) 1- 15' extension with alloy quick connect and male alloy plug 2-Dive lines with Stainless Steel pressed and alloy quick connects (stamped breathing air) 2- Cressi Lo-Pro Regulators with adj. air flow and reusable in-line 40 micron filter 2- Carabiner clips and Gator safety clips for underwater quick connect This reel fits a standard rod holder. Single down hose has a ‘Y’ at the bottom where up to 2 divers can be connected with 20’ hoses each. Goes down to 75’ deep. I’ve only used this less than 6 times. It’s quite literally like new. Asking $1,250. FIRM. Included is a hvy. duty deep cycle battery that will put and keep 2 divers down for up to 3 hours!!! I just don’t use it as much as expected. I can be contacted by phone at 989-714-2553. Best email address is jjmanel@aol.com Joe MANELIS
