length of a text object
K
ken@volksswitch.org
Wed, Nov 28, 2018 4:00 AM
Does anyone know how to determine the length of a text object at run time
(i.e., report its value with an echo command)?
Thanks,
Ken
Does anyone know how to determine the length of a text object at run time (i.e., report its value with an echo command)? Thanks, Ken
NH
nop head
Wed, Nov 28, 2018 7:58 AM
I don't think that is possible but you can make it a specific size using
resize().
Thanks,
Ken
Discuss@lists.openscad.org
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
I don't think that is possible but you can make it a specific size using resize(). On Wed, 28 Nov 2018, 04:01 <ken@volksswitch.org wrote: > Does anyone know how to determine the length of a text object at run time > (i.e., report its value with an echo command)? > > > > Thanks, > > Ken > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
JB
Jordan Brown
Wed, Nov 28, 2018 4:16 PM
Do you mean length as in the number of characters, or length as in the
width of the resulting object?
If you mean the number of characters, the len( ) function does the trick.
If you mean the width... no, though there is a feature that might let
you avoid needing to know.� If you need to center the text object
against something else, or you need to align its right end rather than
its left end, you can use the "halign" parameter of the text( ) function
to specify where the 0,0 point of the object is.� Similarly, though you
don't ask about it, the valign parameter will let you specify vertical
alignment.
For example:
text("ABC", halign="center", valign="center");
will yield "ABC" centered around 0,0.
On 11/27/2018 8:00 PM, ken@volksswitch.org wrote: > > Does anyone know how to determine the length of a text object at run > time (i.e., report its value with an echo command)? > Do you mean length as in the number of characters, or length as in the width of the resulting object? If you mean the number of characters, the len( ) function does the trick. If you mean the width... no, though there is a feature that might let you avoid needing to know.� If you need to center the text object against something else, or you need to align its right end rather than its left end, you can use the "halign" parameter of the text( ) function to specify where the 0,0 point of the object is.� Similarly, though you don't ask about it, the valign parameter will let you specify vertical alignment. For example: text("ABC", halign="center", valign="center"); will yield "ABC" centered around 0,0.
R
runsun
Wed, Nov 28, 2018 6:16 PM
i recall seeing a post in thingiverse doing just that. Too bad I forgot to
make a ref to it at that time, now I can't find it.
$  Runsun Pan, PhD $ libs: scadx , doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), editor of choice: CudaText  ( OpenSCAD lexer ); $ Tips ; $ Snippets
Sent from: http://forum.openscad.org/
i recall seeing a post in thingiverse doing just that. Too bad I forgot to make a ref to it at that time, now I can't find it. ----- $ Runsun Pan, PhD $ libs: scadx , doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), editor of choice: CudaText ( OpenSCAD lexer );&nbsp;$ Tips ;&nbsp;$ Snippets -- Sent from: http://forum.openscad.org/
R
runsun
Wed, Nov 28, 2018 6:29 PM
Before you find a better solution, here is an ugly code that I came up with
years ago. I don't like it but it's the only thing I can find now. Check out
this https://github.com/runsun/OpenSCAD_Tips/blob/master/snippets.md  for
the hash() and you also need to make a sum(...). The isnum() is:
<code>floor(x)==x? true:( abs(x)+1>abs(x))</code>.
function textWidth( txt, size=10, scale=1 )=
(  // A wild guess of what the total width of txt is.
 // symbol width ratios in reference to average char
 // width that is decided by "size"
 let(symbol_w_ratios  =
      "P", 0.906, "Q", 1.055 , "R", 0.98, ".", 0.3768, "1", 0.654
    , "2", 0.7542, "3", 0.7542, "4", 0.7542, "5", 0.7542, "6", 0.7542
    , "7", 0.7542, "8", 0.7542, "9", 0.7542, "S", 0.905, "T", 0.828
    , "U", 0.98 , "V", 0.906, "W", 1.282, "X", 0.906, "Y", 0.906
    , "Z", 0.828, "0", 0.754, "A", 0.903, "B", 0.905, "C", 0.98
    , "D", 0.98, "E", 0.909, "F", 0.83, "G", 1.055, "H", 0.98
    , "I", 0.38, "J", 0.676, "K", 0.905, "L", 0.755, "M", 1.13
    , "N", 0.98, "O", 1.055 , "/", 0.3768, " ", 0.3768, "+", 0.792
    , "-", 0.452, "*", 0.5277, "(", 0.452, ")", 0.452, "a", 0.755
    , "b", 0.755, "c", 0.678, "d", 0.754, "e", 0.754, "f", 0.35
    , "g", 0.754, "h", 0.754, "i", 0.301, "j", 0.301, "k", 0.679
    , "l", 0.301, "m", 1.13, "n", 0.754, "o", 0.754 , "p", 0.754
    , "q", 0.754 , "r", 0.452, "s", 0.678, "t", 0.377, "u", 0.754
    , "v", 0.678, "w", 0.9795, "x", 0.6785, "y", 0.678, "z", 0.678
    , "!", 0.3767, "\"", 0.4815, "#", 0.7543, "$", 0.7543, "%", 1.206
    , "&", 0.904 , "'", 0.259, ",", 0.3768, ":", 0.3768, ";", 0.3768
    , "<", 0.7921, "=", 0.7921, ">", 0.7921, "?", 0.7542, "@", 1.3766
    , "[", 0.3768, "]", 0.3768, "\\", 0.3768, "^", 0.6365, "`", 0.4518
    , "_", 0.75, "|", 0.3522, "~", 0.7921, "{", 0.3625, "}", 0.3625
    , chDEG, 0.5423
     , sz= isnum(size)?size:size[0]//-1
     , sc= isnum(scale)?scale:scale[0]
     , expwidth = sum( [ for(i=range(txt))
                           hash( symbol_w_ratios, txt[i],0.6
                               )*sz*sc  //, sz*sc)
 expwidth
Before you find a better solution, here is an ugly code that I came up with years ago. I don't like it but it's the only thing I can find now. Check out this <https://github.com/runsun/OpenSCAD_Tips/blob/master/snippets.md> for the *hash()* and you also need to make a *sum(...)*. The *isnum()* is: <code>floor(x)==x? true:( abs(x)+1>abs(x))</code>. > function textWidth( txt, size=10, scale=1 )= > ( // A wild guess of what the total width of txt is. > > // symbol width ratios in reference to average char > // width that is decided by "size" > let(symbol_w_ratios = > [ > "P", 0.906, "Q", 1.055 , "R", 0.98, ".", 0.3768, "1", 0.654 > , "2", 0.7542, "3", 0.7542, "4", 0.7542, "5", 0.7542, "6", 0.7542 > , "7", 0.7542, "8", 0.7542, "9", 0.7542, "S", 0.905, "T", 0.828 > , "U", 0.98 , "V", 0.906, "W", 1.282, "X", 0.906, "Y", 0.906 > , "Z", 0.828, "0", 0.754, "A", 0.903, "B", 0.905, "C", 0.98 > , "D", 0.98, "E", 0.909, "F", 0.83, "G", 1.055, "H", 0.98 > , "I", 0.38, "J", 0.676, "K", 0.905, "L", 0.755, "M", 1.13 > , "N", 0.98, "O", 1.055 , "/", 0.3768, " ", 0.3768, "+", 0.792 > , "-", 0.452, "*", 0.5277, "(", 0.452, ")", 0.452, "a", 0.755 > , "b", 0.755, "c", 0.678, "d", 0.754, "e", 0.754, "f", 0.35 > , "g", 0.754, "h", 0.754, "i", 0.301, "j", 0.301, "k", 0.679 > , "l", 0.301, "m", 1.13, "n", 0.754, "o", 0.754 , "p", 0.754 > , "q", 0.754 , "r", 0.452, "s", 0.678, "t", 0.377, "u", 0.754 > , "v", 0.678, "w", 0.9795, "x", 0.6785, "y", 0.678, "z", 0.678 > > , "!", 0.3767, "\"", 0.4815, "#", 0.7543, "$", 0.7543, "%", 1.206 > , "&", 0.904 , "'", 0.259, ",", 0.3768, ":", 0.3768, ";", 0.3768 > , "<", 0.7921, "=", 0.7921, ">", 0.7921, "?", 0.7542, "@", 1.3766 > , "[", 0.3768, "]", 0.3768, "\\", 0.3768, "^", 0.6365, "`", 0.4518 > , "_", 0.75, "|", 0.3522, "~", 0.7921, "{", 0.3625, "}", 0.3625 > > , chDEG, 0.5423 > > ] > , sz= isnum(size)?size:size[0]//-1 > , sc= isnum(scale)?scale:scale[0] > , expwidth = sum( [ for(i=range(txt)) > hash( symbol_w_ratios, txt[i],0.6 > )*sz*sc //, sz*sc) > ] ) > ) > expwidth > ); ----- $ Runsun Pan, PhD $ libs: scadx , doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), editor of choice: CudaText ( OpenSCAD lexer );&nbsp;$ Tips ;&nbsp;$ Snippets -- Sent from: http://forum.openscad.org/
