best way to create this
LA
Lee A
Sat, Feb 27, 2021 9:10 PM
It never occurred to me to try scaling a sphere. I suppose with the
right scale and then pick the section I want I can get most any curve I
want. It would have made my last project easier where I used a really
large sphere to make a small shallow dimple. I will play with this, I
think I can get what I want.
thanks
Lee
On 2/25/2021 11:36 PM, Ron Wheeler wrote:
Not exactly sure that I understand what you want.
This is another approach where I started with a cylinder and
subtracted the bits that I wanted to eliminate.
Perhaps with the right scaling and translating of the circle, you can
get the shape that you want.
It will not give you triangles at the edges but will give you a nice
concave pocket.
$fn=100;
height=20;
base=30;
difference(){
    cylinder(h=height,r=base);
    union(){
      translate([-100,-50,-9]){cube([100,100,base]);}
      translate([5,10,34]){scale([1,1.5,1]){sphere(r=35);}}
If this doesn't quite give you want you want, I hope it gives you some
more ideas about how to use difference and the other tools to make
something by subtracting shapes.
Ron
On 2021-02-25 11:15 p.m., Lee A wrote:
$fn=100;
height=20;
base=30;
for (i=[0:1:180]){
    rotate ([0,0,-i]){
        translate ([-base-3+(i/10),0,0])
        rotate ([270,0,0]){
            linear_extrude(height = 1, center = false, convexity =
10, twist = 0)
            polygon (points=[[0,0],[0,-height+(i/15)],[base-(i/10),0]]);
Ron Wheeler
Artifact Software
438-345-3369
rwheeler@artifact-software.com
It never occurred to me to try scaling a sphere. I suppose with the right scale and then pick the section I want I can get most any curve I want. It would have made my last project easier where I used a really large sphere to make a small shallow dimple. I will play with this, I think I can get what I want. thanks Lee On 2/25/2021 11:36 PM, Ron Wheeler wrote: > Not exactly sure that I understand what you want. > > This is another approach where I started with a cylinder and > subtracted the bits that I wanted to eliminate. > > Perhaps with the right scaling and translating of the circle, you can > get the shape that you want. > It will not give you triangles at the edges but will give you a nice > concave pocket. > > $fn=100; > > height=20; > base=30; > difference(){ >     cylinder(h=height,r=base); >     union(){ >       translate([-100,-50,-9]){cube([100,100,base]);} >       translate([5,10,34]){scale([1,1.5,1]){sphere(r=35);}} >         } > } > > If this doesn't quite give you want you want, I hope it gives you some > more ideas about how to use difference and the other tools to make > something by subtracting shapes. > > Ron > > On 2021-02-25 11:15 p.m., Lee A wrote: >> $fn=100; >> >> height=20; >> base=30; >> >> for (i=[0:1:180]){ >>     rotate ([0,0,-i]){ >>         translate ([-base-3+(i/10),0,0]) >>         rotate ([270,0,0]){ >>             linear_extrude(height = 1, center = false, convexity = >> 10, twist = 0) >>             polygon (points=[[0,0],[0,-height+(i/15)],[base-(i/10),0]]); >>         } >>     } >> } > > -- > Ron Wheeler > Artifact Software > 438-345-3369 > rwheeler@artifact-software.com
LA
Lee A
Sat, Feb 27, 2021 10:28 PM
I reduced this to the minimum to show the message.
Each of the two parts will render just fine by themselves. But when I
render them together I get a message;
UI-WARNING: Object may not be a valid 2-manifold and may need repair!
It is only a warning but I don't like messages in the finished project.
What is the reason for it?
translate ([6.5,2,0]){
    difference (){
    color ("blue")
    cylinder (d=18,h=5);
    color ("red")
    translate ([0,0,-1])
    cylinder (d=15,h=7);
    translate ([-2,-10,-1])
    cube([12,22,7]);
    translate ([-8,-10,-1])
    cube([8,10,7]);
translate ([0,0,0]){
        rotate_extrude (angle=360)
        translate ([2.5,5,0])
polygon(points=[[0,0],[0,1],[1.5,1]]);
thanks
Lee
I reduced this to the minimum to show the message. Each of the two parts will render just fine by themselves. But when I render them together I get a message; UI-WARNING: Object may not be a valid 2-manifold and may need repair! It is only a warning but I don't like messages in the finished project. What is the reason for it? translate ([6.5,2,0]){     difference (){     color ("blue")     cylinder (d=18,h=5);     color ("red")     translate ([0,0,-1])     cylinder (d=15,h=7);     translate ([-2,-10,-1])     cube([12,22,7]);     translate ([-8,-10,-1])     cube([8,10,7]);     } } translate ([0,0,0]){         rotate_extrude (angle=360)         translate ([2.5,5,0]) polygon(points=[[0,0],[0,1],[1.5,1]]); } thanks Lee
F
fred
Sat, Feb 27, 2021 10:34 PM
The "interface" between the lower and upper portions is likely a two-dimensional rendering, a circle. I changed the first translate in the second segment to 0, 0, -0.128 and the error vanished. It won't print well in either circumstance, of course, as there's insufficient material, but I suspect that's not your objective.
On Saturday, February 27, 2021, 5:29:02 PM EST, Lee A <683lee@337lee.com> wrote:
    difference (){
    color ("blue")
    color ("red")
    cube([12,22,7]);
    cube([8,10,7]);
thanks
Lee
Discuss@lists.openscad.org
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
The "interface" between the lower and upper portions is likely a two-dimensional rendering, a circle. I changed the first translate in the second segment to 0, 0, -0.128 and the error vanished. It won't print well in either circumstance, of course, as there's insufficient material, but I suspect that's not your objective. On Saturday, February 27, 2021, 5:29:02 PM EST, Lee A <683lee@337lee.com> wrote: I reduced this to the minimum to show the message. Each of the two parts will render just fine by themselves. But when I render them together I get a message; UI-WARNING: Object may not be a valid 2-manifold and may need repair! It is only a warning but I don't like messages in the finished project. What is the reason for it? translate ([6.5,2,0]){     difference (){     color ("blue")     cylinder (d=18,h=5);     color ("red")     translate ([0,0,-1])     cylinder (d=15,h=7);     translate ([-2,-10,-1])     cube([12,22,7]);     translate ([-8,-10,-1])     cube([8,10,7]);     } } translate ([0,0,0]){         rotate_extrude (angle=360)         translate ([2.5,5,0]) polygon(points=[[0,0],[0,1],[1.5,1]]); } thanks Lee _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
LA
Lee A
Sat, Feb 27, 2021 11:21 PM
Fred,
Right, there is more material to support the second segment so I thought
not a problem.
I think I now understand why it did that. You gave me the solution.
Lee
    difference (){
    color ("blue")
    color ("red")
    cube([12,22,7]);
    cube([8,10,7]);
thanks
Lee
Discuss@lists.openscad.org mailto:Discuss@lists.openscad.org
Fred, Right, there is more material to support the second segment so I thought not a problem. I think I now understand why it did that. You gave me the solution. Lee On 2/27/2021 4:34 PM, fred via Discuss wrote: > The "interface" between the lower and upper portions is likely a > two-dimensional rendering, a circle. I changed the first translate in > the second segment to 0, 0, -0.128 and the error vanished. It won't > print well in either circumstance, of course, as there's insufficient > material, but I suspect that's not your objective. > > On Saturday, February 27, 2021, 5:29:02 PM EST, Lee A > <683lee@337lee.com> wrote: > > > I reduced this to the minimum to show the message. > > Each of the two parts will render just fine by themselves. But when I > render them together I get a message; > > UI-WARNING: Object may not be a valid 2-manifold and may need repair! > > It is only a warning but I don't like messages in the finished project. > What is the reason for it? > > translate ([6.5,2,0]){ >     difference (){ >     color ("blue") >     cylinder (d=18,h=5); >     color ("red") >     translate ([0,0,-1]) >     cylinder (d=15,h=7); >     translate ([-2,-10,-1]) >     cube([12,22,7]); >     translate ([-8,-10,-1]) >     cube([8,10,7]); >     } > } > > translate ([0,0,0]){ >         rotate_extrude (angle=360) >         translate ([2.5,5,0]) > polygon(points=[[0,0],[0,1],[1.5,1]]); > } > > > > > thanks > Lee > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
JB
Jordan Brown
Sun, Feb 28, 2021 1:46 AM
[ By the way... if you're starting a new topic, don't reply to an old
message and just change the subject line.  Threading mail readers will
still see the connection to the existing thread.  Start with a brand new
message. ]
Somebody who understands the math better than I do can perhaps explain
more accurately, but...
The "not manifold" message means basically that you ended up with two
shape sharing the same edge.
The simplest example is this:
cube(10);
translate([10,10,0]) cube(10);
I don't understand why this gives some consumers indigestion, but
apparently it does.  (It's claimed that in less trivial examples it
makes it ambiguous, or at least difficult, to determine which volumes
are inside and outside of the shape.)
Net, always arrange that your models do not share edges.
[ By the way... if you're starting a new topic, don't reply to an old message and just change the subject line.  Threading mail readers will still see the connection to the existing thread.  Start with a brand new message. ] Somebody who understands the math better than I do can perhaps explain more accurately, but... The "not manifold" message means basically that you ended up with two shape sharing the same edge. The simplest example is this: cube(10); translate([10,10,0]) cube(10); I don't understand why this gives some consumers indigestion, but apparently it does.  (It's claimed that in less trivial examples it makes it ambiguous, or at least difficult, to determine which volumes are inside and outside of the shape.) Net, always arrange that your models do not share edges.
RW
Ron Wheeler
Sun, Feb 28, 2021 2:05 AM
This has been a really interesting discussion with lots of new (to me)
ideas presented.
The vagueness of the original request has given lots of scope for
comments and ideas.
I hope that some of the suggestions lead to a solution.
Please post your final solution so that we can all see exactly what you
were trying to achieve.
Ron
thanks
Lee
concave pocket.
$fn=100;
height=20;
base=30;
difference(){
    union(){
some more ideas about how to use difference and the other tools to
make something by subtracting shapes.
Ron
$fn=100;
height=20;
base=30;
for (i=[0:1:180]){
    rotate ([0,0,-i]){
        rotate ([270,0,0]){
10, twist = 0)
            polygon
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
This has been a really interesting discussion with lots of new (to me) ideas presented. The vagueness of the original request has given lots of scope for comments and ideas. I hope that some of the suggestions lead to a solution. Please post your final solution so that we can all see exactly what you were trying to achieve. Ron On 2021-02-27 4:10 p.m., Lee A wrote: > It never occurred to me to try scaling a sphere. I suppose with the > right scale and then pick the section I want I can get most any curve > I want. It would have made my last project easier where I used a > really large sphere to make a small shallow dimple. I will play with > this, I think I can get what I want. > > thanks > Lee > > On 2/25/2021 11:36 PM, Ron Wheeler wrote: >> Not exactly sure that I understand what you want. >> >> This is another approach where I started with a cylinder and >> subtracted the bits that I wanted to eliminate. >> >> Perhaps with the right scaling and translating of the circle, you can >> get the shape that you want. >> It will not give you triangles at the edges but will give you a nice >> concave pocket. >> >> $fn=100; >> >> height=20; >> base=30; >> difference(){ >>     cylinder(h=height,r=base); >>     union(){ >>       translate([-100,-50,-9]){cube([100,100,base]);} >>       translate([5,10,34]){scale([1,1.5,1]){sphere(r=35);}} >>         } >> } >> >> If this doesn't quite give you want you want, I hope it gives you >> some more ideas about how to use difference and the other tools to >> make something by subtracting shapes. >> >> Ron >> >> On 2021-02-25 11:15 p.m., Lee A wrote: >>> $fn=100; >>> >>> height=20; >>> base=30; >>> >>> for (i=[0:1:180]){ >>>     rotate ([0,0,-i]){ >>>         translate ([-base-3+(i/10),0,0]) >>>         rotate ([270,0,0]){ >>>             linear_extrude(height = 1, center = false, convexity = >>> 10, twist = 0) >>>             polygon >>> (points=[[0,0],[0,-height+(i/15)],[base-(i/10),0]]); >>>         } >>>     } >>> } >> >> -- >> Ron Wheeler >> Artifact Software >> 438-345-3369 >> rwheeler@artifact-software.com > -- Ron Wheeler Artifact Software 438-345-3369 rwheeler@artifact-software.com
A
arnholm@arnholm.org
Sun, Feb 28, 2021 9:25 AM
In OpenSCAD and other software based on similar principles, 3d-objects
are described using triangle surface meshes. In other words, objects are
represented as polyhedra with triangular faces (a polyhedron is not
required to have only triangular faces, but that's not a main point
here). In a polyhedron, each face refer to vertices shared with other
faces, and thus they also implicitly share edges with other faces. The
important thing to remember is that for a typical error free polyhedron,
each edge will be shared by exactly 2 faces, i.e. the edge use-count is
2.
Therefore, when something is called "not manifold" it actually means
"not 2-manifold": At least one edge has a use-count different from 2. A
free edge has a use-count of 1 and that's a problem if it is supposed to
be part of of a surface mesh enclosing a solid volume. An edge with a
use count of 3 or more can imply internal faces not part of the surface,
i.e. it has solid material on both sides, and that is understood as a
problem (You could argue that it isn't a problem because such a feature
could be useful in describing an object with different sub-volumes
having different materials, but never mind). It could also imply a free
face with no sold material on either side. You could extend this to more
cases with odd use counts.
But there are also other situations where the edge use count can become
different from 2, the example provided by Jordan Brown is the typical
one: Two cubes positioned so that an edge in cube A coincides with an
edge in cube B. Because they are unioned, cube A and B becomes a single
polyhedron with one shared edge having a use count of 4 (4 faces refer
to it). Still, there is no face with material on both or no sides, all
faces are external as expected. The polyhedron is fine, it just isn't
2-manifold.
The "not manifold" message is therefore not certain to indicate a real
error, but it invites the user to check of something does not look
right.
Carsten Arnholm
On 2021-02-28 02:46, Jordan Brown wrote: > Somebody who understands the math better than I do can perhaps explain > more accurately, but... > > The "not manifold" message means basically that you ended up with two > shape sharing the same edge. In OpenSCAD and other software based on similar principles, 3d-objects are described using triangle surface meshes. In other words, objects are represented as polyhedra with triangular faces (a polyhedron is not required to have only triangular faces, but that's not a main point here). In a polyhedron, each face refer to vertices shared with other faces, and thus they also implicitly share edges with other faces. The important thing to remember is that for a typical error free polyhedron, each edge will be shared by exactly 2 faces, i.e. the edge use-count is 2. Therefore, when something is called "not manifold" it actually means "not 2-manifold": At least one edge has a use-count different from 2. A free edge has a use-count of 1 and that's a problem if it is supposed to be part of of a surface mesh enclosing a solid volume. An edge with a use count of 3 or more can imply internal faces not part of the surface, i.e. it has solid material on both sides, and that is understood as a problem (You could argue that it isn't a problem because such a feature could be useful in describing an object with different sub-volumes having different materials, but never mind). It could also imply a free face with no sold material on either side. You could extend this to more cases with odd use counts. But there are also other situations where the edge use count can become different from 2, the example provided by Jordan Brown is the typical one: Two cubes positioned so that an edge in cube A coincides with an edge in cube B. Because they are unioned, cube A and B becomes a single polyhedron with one shared edge having a use count of 4 (4 faces refer to it). Still, there is no face with material on both or no sides, all faces are external as expected. The polyhedron is fine, it just isn't 2-manifold. The "not manifold" message is therefore not certain to indicate a real error, but it invites the user to check of something does not look right. Carsten Arnholm
AM
Adrian Mariano
Sun, Feb 28, 2021 4:44 PM
While correct in some ways, I think that description is a little bit
confusing as well.  A manifold as a mathematical object is something which
locally looks like Euclidean space.  A  2d manifold or 2-manifold locally
looks like a plane, the 2d Euclidean space.  A line on a plane divides the
plane into two sides, which is why there must be two faces at an edge.  If
there is only one face, or if there are 3 or more, than at that edge the
structure doesn't resemble a plane.  The 2 in the term 2-manifold has
nothing to do with there being two faces at each edge.  If you join two
cubes along an edge then at that joint the structure does not look
plane-like, hence it is not a two-dimensional manifold.  CGAL, which
OpenSCAD uses for its calculations, requires that all of the objects you
construct be 2-manifolds, so if they aren't, you're likely going to have
some trouble.  This can happen because an edge has the wrong number of
faces (not exactly 2), or because faces intersect each other, or faces are
reversed, so edge AB on one face maps to BA on another face.  (This
reversal puts a twist into the manifold and actually is mathematically
acceptable, but it makes the manifold non-orientable and impossible to
embed in 3d space, so it's bad for modeling real world objects.)
2.
2-manifold.
right.
Carsten Arnholm
While correct in some ways, I think that description is a little bit confusing as well. A manifold as a mathematical object is something which locally looks like Euclidean space. A 2d manifold or 2-manifold locally looks like a plane, the 2d Euclidean space. A line on a plane divides the plane into two sides, which is why there must be two faces at an edge. If there is only one face, or if there are 3 or more, than at that edge the structure doesn't resemble a plane. The 2 in the term 2-manifold has nothing to do with there being two faces at each edge. If you join two cubes along an edge then at that joint the structure does not look plane-like, hence it is not a two-dimensional manifold. CGAL, which OpenSCAD uses for its calculations, requires that all of the objects you construct be 2-manifolds, so if they aren't, you're likely going to have some trouble. This can happen because an edge has the wrong number of faces (not exactly 2), or because faces intersect each other, or faces are reversed, so edge AB on one face maps to BA on another face. (This reversal puts a twist into the manifold and actually is mathematically acceptable, but it makes the manifold non-orientable and impossible to embed in 3d space, so it's bad for modeling real world objects.) On Sun, Feb 28, 2021 at 4:26 AM <arnholm@arnholm.org> wrote: > On 2021-02-28 02:46, Jordan Brown wrote: > > Somebody who understands the math better than I do can perhaps explain > > more accurately, but... > > > > The "not manifold" message means basically that you ended up with two > > shape sharing the same edge. > > In OpenSCAD and other software based on similar principles, 3d-objects > are described using triangle surface meshes. In other words, objects are > represented as polyhedra with triangular faces (a polyhedron is not > required to have only triangular faces, but that's not a main point > here). In a polyhedron, each face refer to vertices shared with other > faces, and thus they also implicitly share edges with other faces. The > important thing to remember is that for a typical error free polyhedron, > each edge will be shared by exactly 2 faces, i.e. the edge use-count is > 2. > > Therefore, when something is called "not manifold" it actually means > "not 2-manifold": At least one edge has a use-count different from 2. A > free edge has a use-count of 1 and that's a problem if it is supposed to > be part of of a surface mesh enclosing a solid volume. An edge with a > use count of 3 or more can imply internal faces not part of the surface, > i.e. it has solid material on both sides, and that is understood as a > problem (You could argue that it isn't a problem because such a feature > could be useful in describing an object with different sub-volumes > having different materials, but never mind). It could also imply a free > face with no sold material on either side. You could extend this to more > cases with odd use counts. > > But there are also other situations where the edge use count can become > different from 2, the example provided by Jordan Brown is the typical > one: Two cubes positioned so that an edge in cube A coincides with an > edge in cube B. Because they are unioned, cube A and B becomes a single > polyhedron with one shared edge having a use count of 4 (4 faces refer > to it). Still, there is no face with material on both or no sides, all > faces are external as expected. The polyhedron is fine, it just isn't > 2-manifold. > > The "not manifold" message is therefore not certain to indicate a real > error, but it invites the user to check of something does not look > right. > > Carsten Arnholm > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
RP
Ronaldo Persiano
Tue, Mar 2, 2021 7:21 PM
Just to complement the excellent explanation of @adrianv: when, let's say,
two cubes have just one point in common we don't have a 2-manifold because
the surface locally doesn't look like a two dimension Euclidean space at
that point. That happens for instance when a vertex of one cube is on a
vertex, an edge or a face of the other (and only that point in common with
it).
Em dom., 28 de fev. de 2021 às 16:45, Adrian Mariano avm4@cornell.edu
escreveu:
2.
2-manifold.
right.
Carsten Arnholm
Just to complement the excellent explanation of @adrianv: when, let's say, two cubes have just one point in common we don't have a 2-manifold because the surface locally doesn't look like a two dimension Euclidean space at that point. That happens for instance when a vertex of one cube is on a vertex, an edge or a face of the other (and only that point in common with it). Em dom., 28 de fev. de 2021 às 16:45, Adrian Mariano <avm4@cornell.edu> escreveu: > While correct in some ways, I think that description is a little bit > confusing as well. A manifold as a mathematical object is something which > locally looks like Euclidean space. A 2d manifold or 2-manifold locally > looks like a plane, the 2d Euclidean space. A line on a plane divides the > plane into two sides, which is why there must be two faces at an edge. If > there is only one face, or if there are 3 or more, than at that edge the > structure doesn't resemble a plane. The 2 in the term 2-manifold has > nothing to do with there being two faces at each edge. If you join two > cubes along an edge then at that joint the structure does not look > plane-like, hence it is not a two-dimensional manifold. CGAL, which > OpenSCAD uses for its calculations, requires that all of the objects you > construct be 2-manifolds, so if they aren't, you're likely going to have > some trouble. This can happen because an edge has the wrong number of > faces (not exactly 2), or because faces intersect each other, or faces are > reversed, so edge AB on one face maps to BA on another face. (This > reversal puts a twist into the manifold and actually is mathematically > acceptable, but it makes the manifold non-orientable and impossible to > embed in 3d space, so it's bad for modeling real world objects.) > > On Sun, Feb 28, 2021 at 4:26 AM <arnholm@arnholm.org> wrote: > >> On 2021-02-28 02:46, Jordan Brown wrote: >> > Somebody who understands the math better than I do can perhaps explain >> > more accurately, but... >> > >> > The "not manifold" message means basically that you ended up with two >> > shape sharing the same edge. >> >> In OpenSCAD and other software based on similar principles, 3d-objects >> are described using triangle surface meshes. In other words, objects are >> represented as polyhedra with triangular faces (a polyhedron is not >> required to have only triangular faces, but that's not a main point >> here). In a polyhedron, each face refer to vertices shared with other >> faces, and thus they also implicitly share edges with other faces. The >> important thing to remember is that for a typical error free polyhedron, >> each edge will be shared by exactly 2 faces, i.e. the edge use-count is >> 2. >> >> Therefore, when something is called "not manifold" it actually means >> "not 2-manifold": At least one edge has a use-count different from 2. A >> free edge has a use-count of 1 and that's a problem if it is supposed to >> be part of of a surface mesh enclosing a solid volume. An edge with a >> use count of 3 or more can imply internal faces not part of the surface, >> i.e. it has solid material on both sides, and that is understood as a >> problem (You could argue that it isn't a problem because such a feature >> could be useful in describing an object with different sub-volumes >> having different materials, but never mind). It could also imply a free >> face with no sold material on either side. You could extend this to more >> cases with odd use counts. >> >> But there are also other situations where the edge use count can become >> different from 2, the example provided by Jordan Brown is the typical >> one: Two cubes positioned so that an edge in cube A coincides with an >> edge in cube B. Because they are unioned, cube A and B becomes a single >> polyhedron with one shared edge having a use count of 4 (4 faces refer >> to it). Still, there is no face with material on both or no sides, all >> faces are external as expected. The polyhedron is fine, it just isn't >> 2-manifold. >> >> The "not manifold" message is therefore not certain to indicate a real >> error, but it invites the user to check of something does not look >> right. >> >> Carsten Arnholm >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
